Old 02-22-2014, 09:09 PM   #1
Plain Old Member
Latest Modifications - 35QB4 - WH Switch, Air Deflector
Did a few more modifications today I thought I'd share here since it's Cedar Creek / Silverback specific. These mods are all over this forum, at least one of them, but figured I'd post my version.
1) Water heater electric switch. Everybody knows about the typical Suburban electric switch located on the outside. The receptacle for the electric part is located behind the water heater. All I did was replace the receptacle and install a switch in the hallway that turns it on or off. The switch on the water heater itself stays in the "On" position.
2) AC deflector, or "tent" as it's called by the creator. I robbed this from the Heartland forum. There were several people there complaining of the cooling efficiency of the roof units in the summer, plus lack of air flow. The problem may be brand specific, but figured I'd try it as most RV's have the ducts tied to the AC unit the same way. One problem was how the air discharge is configured in relation to the duct tie ins creating turbulence before the air hits the ducts. This guy made a deflector that directs the air straight from the blower to the ducts. You lose the effectiveness of the quick cool vent, but you increase the quality of air flow to the ducts. I did this on the front and rear AC, and it does make a difference.
Name:	WH Electric Switch.jpg
ID:	46651   Click image for larger version
Name:	AC Deflector 1.jpg
ID:	46652   Click image for larger version
Name:	AC Deflector 2.jpg
ID:	46653   Click image for larger version
Name:	AC Deflector 3.jpg
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 02-23-2014, 08:36 PM   #2
Think I just found two new mods for the rig this year! Thanks for the info.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
modifications, 35qb4, cat
