Old 03-28-2016, 06:08 PM   #1
Leak through light fixture river creek 30rgbs
I left the slider open last night and it was raining today and water came down the light fixture! Any suggestions where it came down from I see there is a patch job on the slider but not where it was leaking! Also what can I use to fix this problem!
teencee1 is offline   Reply With Quote
Old 03-31-2016, 04:50 PM   #2
Leak threw light fixture river creek 30rgbs
Sorry no one has replied, please take and post a few pics of the slide and patch. Water travels the path of least resistance heading down. So it could be entering at any point and traveling a wire, frame member, etc to the light fixture. Getting up and looking and resealing everything is a start.
Rich5117 is offline   Reply With Quote
Old 03-31-2016, 07:17 PM   #3
Old 04-01-2016, 01:59 PM   #4
Old Member
Take a look at this thread Slide seal and sealing questions
Check along the screw line on the outer edge of the slideout roof. If there are any screw heads poking through the tape or the tape isn't completely stuck down. Check carefully on the outer edge of the tape where it comes up against the angle.
Cool Canuck is offline   Reply With Quote
Old 04-06-2016, 06:41 AM   #5
Ok thank you! I will check it out
leak, light
