Old 04-02-2019, 07:35 AM   #1
SilhouettePenny's Avatar
Learning the In-Command, Gas/Electric Water Heater
With campers of the past a simple on/off switch controlled the electric water heater function from inside. But In-Command does not have an on/off option on the Display Commander (DC) and simply unselecting or ghosting the option does not turn it off.
After a recent trip I was unselecting Gas/Electric/Both on the DC then plugged in to the house in order to maintain the battery. To my suprise the water heater was still functioning days later. Thankfully I forgot to empty the tank.
I suppose the solution is to utilize the on/off switch outside as I drain the unit. Has anybody with the In-Command system modified the menu to completely turn off the water heater from inside the coach?
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 04-02-2019, 07:46 AM   #2
I'd be interested as well. depending on the responses, I may be adding a switch.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 04-02-2019, 08:16 AM   #3
Moving the electric switch from outside at the water heater to the inside control panel area is a great idea....we can mount it right next to the Gas Option Switch which they DID install inside!Click image for larger version
2019.5 Hathaway
Old 04-02-2019, 08:38 AM   #4
I don't have the In-Command but if you have a separate INSIDE control switch for the gas and an OUTSIDE control switch for electric, what does the DC option of Gas/Electric/Both do?
Just trying to learn.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 04-02-2019, 09:12 AM   #5
The only logic I can think to apply here is "The people that build 'em certainly don't use them". The Display Commander will turn on the electric water heater IF the mechanical/electrical switch outside is on.
2019.5 Hathaway
Old 04-02-2019, 09:38 AM   #6
Then why doesn't it allow you to turn it off?
Old 04-02-2019, 09:45 AM   #7
I may be an old dog, but sometimes...."Technology" does NOT always make these easier. Our old 2007 Jayco TT, Two switchers on the wall...one turned on the electric side of the WH, the other turned on the Gas side. SIMPLE !!!
TheWolfPaq82 is offline   Reply With Quote
Old 04-02-2019, 09:52 AM   #8
That's the $20,000 question! Probably a simple option change in the mode settings, which I have not discovered yet.
2019.5 Hathaway
Old 04-02-2019, 09:56 AM   #9
Roger that!
Once you figure it out, let us know.
As I said, tryin' to learn...
Old 04-02-2019, 10:47 AM   #10
Moving the electric switch from outside at the water heater to the inside control panel area is a great idea....we can mount it right next to the Gas Option Switch which they DID install inside!Attachment 200529
If we need to do that, I think it would be easier to run a multi-pair cable from the InCommand panel in the basement to that closet area. We're not getting solar or gen so lots of room for more switches. I plan to do that anyway because we're assuming, we will want to separate out some lighting circuits.
Cathy & Jeff
Midland, Michigan
Old 04-02-2019, 07:24 PM   #11
Same with...
Same with our 2002 Nash. I'm adding an inside switch to the 2007 Cherokee 38P Destination Trailer. Will post photos and instructions.
Larry
Larry-NC is offline   Reply With Quote
Old 04-03-2019, 09:06 AM   #12
I have a 2019 31IK with the In-Command system. I don't think the water heater is hooked up to it so it can't be controlled by it. Why else would there be a physical switch to turn it on gas? The first time I tried to use it via electric I turned in on via the panel. Nothing. I had to turn the power switch on at the water heater. Maybe in later built trailers it'll be hooked up.
BarnhartRAM is offline   Reply With Quote
Old 04-03-2019, 09:19 AM   #13
I'm wondering if you ever really "turned it on;" I'm thinking maybe it was on all along.
Check your WH model number. If it has an L at the end (e.g. SW6DEL), then it has a 12VDC circuit that can energize a relay and turn on the 110VAC electric. This circuit could be controlled by either a switch (for most of us) or by your DC system. But if your WH doesn't have an L in the model number, then the only electric ON/OFF control is the outside switch.
I'm guessing the DC system has the WH electric control built-in, but that it doesn't really do anything if you don't have an "L" model WH.
2011 Traverse LT, 3.6L, FWD
Old 04-03-2019, 09:41 PM   #14
ImQAJack's Avatar
About a Month ago I was looking in on this issue. Still collecting any info. My original thought the command center switch controls the HW is on or off, and the switch outside controls heat source (Gas or Electric). I was surprise to find I had Hot water when I'm hookup to shore power.
More studying is need to be done to make so.
ImQAJack is offline   Reply With Quote
Old 04-05-2019, 05:27 PM   #15
Iím having trouble getting hot water. Hereís the pic of how it works and how I have it set.
I post a pic how I have it next.
MikeRP is offline   Reply With Quote
Old 04-05-2019, 05:34 PM   #16
Old 04-05-2019, 05:39 PM   #17
MIke, turn the blue one.
Originally Posted by MikeRP View Post
Mike, turn the blue (bottom) one. The red one is correct.
Also, if you have showers (inside and outside) that have a shutoff on the showerhead, make sure the Hot and Cold taps are both off. Otherwise the hot and cold will mix.
Larry
Old 04-05-2019, 06:13 PM   #18
Mike, you basically have Option #4b in the attached, with the hot side Tee turned 90 degrees.
Old 04-05-2019, 08:41 PM   #19
Thank you Rockford, that setup is a little arcane coming from a Sunseeker. I got it figured out and walla it works. Thanks!
Old 04-06-2019, 08:44 AM   #20
Hey Larry thanks also, I got there by process of elimination. One thing it that I wasnít patient enough, this water heater takes longer to heat the water than my old Sunseeker.
Actually seems like a nice system.
electric, gas, heater, select, water, water heater
