Old 12-29-2015, 09:58 PM   #11
Have the same 5vr. Which lights are they? All of ours seem to be operating ok.
Mahlstedtd is offline   Reply With Quote
Old 12-29-2015, 10:18 PM   #12
DougP47's Avatar
I installed these in each light. they are a DC 1.5-35VDC voltage stepdown regulator p/n DSN2596 that I have adjusted to 10.5 vdc. I can leave on all day and the cover is as cool even if a light is setting on the cover. I use Velcro with sticky back to mount the light inside the lamp. on ebay #LM2596 I think you can get 10 for under $12.00 :thumbsup
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 12-29-2015, 10:23 PM   #13
Wow seems like the RV industry needs to address this safety issue before a deadly fire occurs.
Dakota C Creek is offline   Reply With Quote
Old 12-29-2015, 10:30 PM   #14
Forbes's Avatar
Originally Posted by DougP47 View Post
I installed these in each light. they are a 12vdc voltage regulator that I have adjusted to 10.5 vdc. I can leave on all day and the cover is as cool even if a light is setting on the cover. I use Velcro with sticky back to mount the light inside the lamp.
Can you please post regulator number and where you got them. I could build some up but just a cheap to buy them.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Days Camping 2014-96, 2015-130, 2016-126, 2017-42 and counting
Forbes is offline   Reply With Quote
Old 12-29-2015, 10:47 PM   #15
DougP47's Avatar
Forbes I edit my post with part # and where I bought them from. After I posted I thought I should have added the info. will that work for you.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 12-29-2015, 11:29 PM   #16
Forbes's Avatar
Works great for me, can't build them for that...ordering 20
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
Old 12-30-2015, 12:08 AM   #17
DougP47's Avatar
Now for the overhead bedroom lights I adjusted to volts to 5vdc output. We did not need them that bright. One of the great things about the regulator go 1.5 vdc if you want to.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 12-30-2015, 08:59 AM   #18
I replaced all of the interior incandescent bulbs in my Georgetown 327DS with LEDs a couple of years ago. I ordered 48LED flat panel assemblies and installed one of those little regulators in the center section of each of the double bulb pancake fixtures. They work like a charm and I haven't had a single failure of an LED panel. Mine are set, I believe, to 11.2V which runs the LEDs at just below maximum brightness and has them cool enough to comfortably hold in your hand.
The scary part of this modification was removing the fixtures. The ceiling fixture that we had on the most had a nice burnt brown color under it.
Phil
pmsherman is offline   Reply With Quote
Old 12-30-2015, 09:55 AM   #19
Usually Confused Member
emm-dee's Avatar
I found that all the overhead lights in my Vengeance were pretty warm. When I removed the covers found the area immediately around the bulbs to be pretty hot. Four of the bulbs showed areas of scorching at the point where the bulb plugged in to the fixture (two bulbs per fixture). I replaced all 26 bulbs with LED (921 series) and now they are just barely warm at the connection. With the lens covers on I cannot feel any heat when touching the exterior of the fixtures.
Once I get the new tail/turn signal lights installed the entire trailer will have LED lights only.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-04-2016, 07:37 PM   #20
We have a 2015 36CKTS. Picked it up Feb 1 2015 and within 30 days the lights started going out. Some burnt the covers some just quit . CC sent me enough new ones to replace everyone of mine. I have replaced all but 4 . Those original 4 are still working GREAT.l
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
cover, led, light
