Dunk with 2016 Cedar Creek 38FB2, after you replaced all of your factory installed LED ceiling lights, did the replacements start to burn out. Post #12 stated that we need to do a better job of controlling the voltage to the lights and make sure that the voltage does not go above 12 volts. If that is so, why is Forest River not putting in a voltage converter that controls the voltage to 12 volts max.
