Thought I would post where to get the small Domed Puck Lights that are common in Cedar Creeks since it took a bit of time to track it down. If you pop the dome off and unscrew one from the ceiling and you see Model # SL206M2 stamped on the back here is the vendor.
I am the 2nd owner of my rig but I think that it has a lifetime warranty to the 1st owner. If you are not the 1st they are dirt cheap like $5 for the reg type controlled by a wall switch and $7 for those with the on/off button built in.
I really like the lighting that these little guys produce over the traditional automotive bulb monsters up til now. Much less power consumption and heat too!
Trent Weaver is the contact there and was fantastic to work with, A+ company and always kept me informed and responded to every question I had very fast.
Only negative is they do not accept paypal or credit cards, you will need to send a check if you are out of warranty.
Send Trent a email I enclosed below and he can help you out....
Bright Ideas LLC
2322 Primrose Ave.
Elkhart, IN. 46516
tntbrightideasllc@gmail.comd
