Old 06-04-2013, 08:36 PM   #1
Level-up
I have the Level-up on my 30RL and I really like it, the manual says to try to find level ground to sit up camper. Most places I go do not have level ground, so I fool the dumb system. What I do is measure from the jack pad closer to the ground and then start from there. I put jack pads under all the other jacks to bring every thing up to level, it only takes a minute or two, then hit the auto level. Bingo no tires off the ground, camper nice and level, works like a charm. I keep all the jacks at least 8 inches or more between the jacks and the pads, it works for me. Before I started this sometimes I would have tires off the ground and sometimes camper could not get level, now camper gets level everytime. It may be wrong but it works for me.
spock123 is online now   Reply With Quote
Old 06-05-2013, 01:20 PM   #2
Well, I don't think you are wrong! Obviously so, since I do exactly the same thing. Even though LCI tech guy told me that having the tires a bit off the ground won't matter, I like having the tires firmly on the ground. I think it adds stability to the camper.
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 06-09-2013, 10:24 PM   #3
Great suggestion, as I look at my 5th, one set of tires are off the ground!
_______________
2011 Ford F350 Diesel Lariat with Firestone Airbags and Ford installed Reese Elite 18K 5th
2011 Cedar Creek 36RE Touring Edition - Loaded
djkarau is offline   Reply With Quote
Old 06-10-2013, 11:52 AM   #4
At one point I would end up with the left side tires as much as 6" off the ground. Even LCI says that is too much. In fact it was during a conversation with the LCI tech guy that he ran me through the "zeroing" procedure on the level-up system. I've got all the steps printed out on a sheet of paper but can't remember them all right now. But after doing that procedure, the systems works very well on a nearly level to level site. If the site is not level, that is where I have to use the jack pads.
Skip & Susan Orrell
Hurst, Texas
Old 06-10-2013, 04:08 PM   #5
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
I have & use the day lights out of the level-up. I use the same jack pads regardless of how level the site is or is not. Tires stay on ground here thy belong. I recommend zeroing they system when you return home, this allows a system reset when time is on your side and makes the trailer ready for hat future outting.
Travel safe & enjoy your ride.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 06-10-2013, 04:14 PM   #6
Former Full Timer
Duckogram's Avatar
You can raise the 4 rear jacks a notch or two and eliminate the high altitude leveling. The dealer suggested that they come mounted too low from the factory and recommended raising them so I took his advice. Have never had a problem with them and the Creek sits lower making it easier to get up those steps (QuadraStep ).
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 06-16-2013, 05:25 PM   #7
level up
I too have the level up system on my Crusader, my question is what brand of pad is everyone using? thanks
2013 Crusader 325RES
2006 Chevy 2500 CC/SB Duramax/Ally 4X4
rhollar is offline   Reply With Quote
Old 06-16-2013, 07:43 PM   #8
Former Full Timer
Duckogram's Avatar
I use 2x10's. I have 6 pads with 3 2x10's screwed together and added plastic handles for toting. I also have 6 singles in case 3 are too much or not enough. I keep them in a plastic laundry basket in the bed of the TV. I also have a set of the plastic interlocking Camco pads left over from pre level up days.
Old 06-18-2013, 02:53 PM   #9
We were at "The Rally" this weekend and had a major slope to the door side AND front and leveled without problems.
Once level the tires were about 6" off the ground - lifted it a little higher and stacked wood under the tires and returned back to level.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 06-19-2013, 07:25 PM   #10
OL Creeker's Avatar
For our future CC, I have six pieces of 12" sq., 1 1/2" thick cedar boards, stained and ready to go.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
