06-04-2013, 08:36 PM
Level-up
I have the Level-up on my 30RL and I really like it, the manual says to try to find level ground to sit up camper. Most places I go do not have level ground, so I fool the dumb system. What I do is measure from the jack pad closer to the ground and then start from there. I put jack pads under all the other jacks to bring every thing up to level, it only takes a minute or two, then hit the auto level. Bingo no tires off the ground, camper nice and level, works like a charm. I keep all the jacks at least 8 inches or more between the jacks and the pads, it works for me. Before I started this sometimes I would have tires off the ground and sometimes camper could not get level, now camper gets level everytime. It may be wrong but it works for me.
06-05-2013, 01:20 PM
Well, I don't think you are wrong! Obviously so, since I do exactly the same thing. Even though LCI tech guy told me that having the tires a bit off the ground won't matter, I like having the tires firmly on the ground. I think it adds stability to the camper.
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
06-09-2013, 10:24 PM
Great suggestion, as I look at my 5th, one set of tires are off the ground!
_______________
2011 Ford F350 Diesel Lariat with Firestone Airbags and Ford installed Reese Elite 18K 5th
2011 Cedar Creek 36RE Touring Edition - Loaded
06-10-2013, 11:52 AM
At one point I would end up with the left side tires as much as 6" off the ground. Even LCI says that is too much. In fact it was during a conversation with the LCI tech guy that he ran me through the "zeroing" procedure on the level-up system. I've got all the steps printed out on a sheet of paper but can't remember them all right now. But after doing that procedure, the systems works very well on a nearly level to level site. If the site is not level, that is where I have to use the jack pads.
Skip & Susan Orrell
Hurst, Texas
06-10-2013, 04:08 PM
Old Member
I have & use the day lights out of the level-up. I use the same jack pads regardless of how level the site is or is not. Tires stay on ground here thy belong. I recommend zeroing they system when you return home, this allows a system reset when time is on your side and makes the trailer ready for hat future outting.
Travel safe & enjoy your ride.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
06-10-2013, 04:14 PM
Certified Curmudgeon
You can raise the 4 rear jacks a notch or two and eliminate the high altitude leveling. The dealer suggested that they come mounted too low from the factory and recommended raising them so I took his advice. Have never had a problem with them and the Creek sits lower making it easier to get up those steps (QuadraStep ).
Mike Dropped
06-16-2013, 05:25 PM
level up
I too have the level up system on my Crusader, my question is what brand of pad is everyone using? thanks
2013 Crusader 325RES
2006 Chevy 2500 CC/SB Duramax/Ally 4X4
06-16-2013, 07:43 PM
I use 2x10's. I have 6 pads with 3 2x10's screwed together and added plastic handles for toting. I also have 6 singles in case 3 are too much or not enough. I keep them in a plastic laundry basket in the bed of the TV. I also have a set of the plastic interlocking Camco pads left over from pre level up days.
Mike Dropped
06-18-2013, 02:53 PM
We were at "The Rally" this weekend and had a major slope to the door side AND front and leveled without problems.
Once level the tires were about 6" off the ground - lifted it a little higher and stacked wood under the tires and returned back to level.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
06-19-2013, 07:25 PM
For our future CC, I have six pieces of 12" sq., 1 1/2" thick cedar boards, stained and ready to go.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
