Old 08-21-2015, 08:12 AM   #1
Level Up Question
Just to the right of the level up controls in my Silverback 29RE there is a white rocker switch. What is the purpose of this switch?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 08-21-2015, 08:34 AM   #2
jaygeo1's Avatar
the white rocker button
It will allow you to operate your slide outs from that side of the coach.
jaygeo1 is offline   Reply With Quote
Old 08-21-2015, 10:40 AM   #3
Hmmm... I learn something every day! I hadn't noticed that white rocker switch. I can't think it would be useful very often. I'd much rather be inside watching the slides move.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 08-21-2015, 11:58 AM   #4
jaygeo1's Avatar
The white rocker button.....
I believe it is there so you can keep an eye on the bedroom & Kitchen slides if the 5th wheel is in a "tight" spot to make sure you have clearance to open..
Old 08-21-2015, 03:05 PM   #5
arpipeliner's Avatar
On mine it turns on the lights above the pin box.
arpipeliner is offline   Reply With Quote
Old 08-21-2015, 04:42 PM   #6
[QUOTE=arpipeliner;960483]On mine it turns on the lights above the pin box.
/QUOTE]
My front cap light is in the underbelly compartment just to the right of the drain valves. My dealer conveniently labeled it cap light. But we're talking about the white rocker switch in the battery compartment just to the right of the level up control panel. I have no label on this switch.
Or maybe yours is just different from mine...
F-350 Dually
Old 08-21-2015, 05:22 PM   #7
You are right. My switch is beside the out door shower. Only used it once. I don't have a switch by my front legs switch.
