Old 06-08-2011, 09:15 PM   #11
rrdrtravelers's Avatar
Thumbs up
Originally Posted by Oilmaggott View Post
Actually I am very impressed with the system. I would not own a fifth wheel without it now that I have been using it. I think the only problem is it is so new most RV dealers are not trained on how to use it. On our walkthrough the dealer just told us when we figured out how it worked come back and show. Them. Also a more complete owners manual would help till the dealers are more trained. My trailer didn't even include one, had to pull it up on the Internet.
Thanks for the feedback. That eases our minds and helps us with it when take delivery next Friday. The dealer said they make sure everything is in working order before we pick it up. I feel confident we won't take it until all is working properly and to our satisfaction.
2011 Cedar Creek 36RE
2002 Ford F350 Crew Cab 4x4
rrdrtravelers is offline   Reply With Quote
Old 06-08-2011, 09:23 PM   #12
Bill_C's Avatar
What is a 'Level-Up System?'
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 06-08-2011, 09:34 PM   #13
Oilmaggott's Avatar
It is a new six point hydraulic leveling system that automatically levels the unit in under a min. Once down the trailer has no wobble, it is just like it is sitting on a slab.
Oilmaggott is offline   Reply With Quote
Old 06-08-2011, 09:43 PM   #14
Any hints/tips on using the system? What do you use to check level? Or does it automatically know level? I'm envisioning it as hydraulic lifts that you have to adjust up/down until you find level. But does the system find level for you?
Old 06-08-2011, 09:54 PM   #15
Oilmaggott's Avatar
It is all computer controlled. All you do after un hitching is push a button and watch. The oil level is checked with jacks up. See clear plastic reservoir. Should be almost full. Check out the yutube video. Search for wildcat level up.
Old 06-08-2011, 09:56 PM   #16
Oilmaggott's Avatar
Here is the link to the owners manual.
http://www.lippertcomponents.com/Own...pAutomatic.pdf
Old 06-08-2011, 10:30 PM   #17
Awesome! You rock. Thanks so much.
Old 06-09-2011, 08:41 AM   #18
Bill_C's Avatar
Thanks for the answers everyone ! It sounds like quite a system. Expensive motor coaches have this system. The warning of looking out for the legs as they come down is a good one. A fellow had a starting problem with his coach. A fellow camper went under to give the starter a wack for him. While under the coach the owner for some reason decided he would help my raising the coach with the auto leveller. That leg came down fast and hit the ground right beside the guys head.
I can see someone trying to set a pad under a leg while the operator pushes the level button.
Old 06-09-2011, 10:07 AM   #19
Just wait until someone's child gets killed by one of these things.
Sometimes "convenience" isn't worth the price.
Old 06-09-2011, 10:21 AM   #20
My first experience with the level up was questionable. I followed the directions as stated to raise the 5er back to orignal position by pushing left/right arrows simutanious and keep getting the error message. After talking with Lippert and doing a couple tests we found that if the original position when coming off of the truck was higher than level, the feature works. If when coming off the truck you are at a spot lower than level it will give you the error message. Also I had been under the thought that you shouldn't back under the trailer with all the rear stablizers down. Not true by Lippert. If you get the fail error code simply do the clear entry and raise your front to the point to get back on the trailer then do the auto retract and all the jacks come up. Once I figured out the a,b,c (s) it works great. Their instructions could be more clear no doubt. The dealer surely didn't have a clue.
glendodom is offline   Reply With Quote
