On level ground, I've run the LCI reset procedure many times while completely unhooked. You use manual mode to get each jack extended 6" to 8" (no more, no less). Then press and hold the retract button to have all Jack's start to retract. Once they start, let go of the retract button and they should all complete their up and this process clears any errors. The 5er will not fall and you can then drop front Jack's and level as usual.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
