Old 04-08-2013, 07:06 PM   #1
Papi
Papicamper's Avatar
Leveler Reliability Question
Here's one for the greater minds that I know are out there...
My 36CKTS (I love it!) is sitting in the yard parking place...we're between trips. The question is: Having used the autoleveling system (I love it!) in the yard...is there any issue due to just having it parked there for sustained periods. I mean should I be doing something else to keep it properly maintained while "sitting" extended, etc. I don't want to abuse the system and want to make sure I'm not doing so. Thanks!
PapiCamper
Cedar Creek 36CKTS
F350 Lariat ("Big Blue")
Papicamper is offline   Reply With Quote
Old 04-08-2013, 07:21 PM   #2
Former Full Timer
Duckogram's Avatar
The manual sez to spray the exposed legs with silicone spray weekly. Since mine sits for 7 months (with us in it), I use blocks to minimize the exposed rams and spray them weekly as recommended. No pitting or rust here.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 04-09-2013, 07:20 AM   #3
Ours sits all winter - blocks to minimize exposure and the spray once a week...
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-09-2013, 11:52 AM   #4
BoatDude's Avatar
I asked a tech the same question. He said to use WD-40 to prevent surface rust on the cylinders. Also the slide mechanism bars and use a silicone grease on the gears and racks.
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 04-09-2013, 05:46 PM   #5
Former Full Timer
Duckogram's Avatar
Your "Tech" may not be as correct as he/she needs to be. WD-40 may not be compatible with the seals or the transmission fluid if it makes it past the seal. WD-40 also has other properties that
could cause damage due to their nature over time.
As for the slideouts I quote from Lippert: "The Lippert Hydraulic Slideout System has been static tested to over 4,000 continuous cycles with out any noticeable wear to rotating or sliding parts. It is recommended that when operating in harsh environments (road salt, ice build up, etc.) the moving parts be kept clean and can be washed with mild soap and water. No grease or lubrication is necessary and in some situations may be detrimental to the environment and long term dependability of the system."
Bottom line is unless your "tech" is smarter than the engineers that made this stuff, one might consider sticking to what the folks that design this stuff recommend.
Of course, if one is going to ignore good counsel and go rogue on the subject, why not use cosmoline?
I don't mean for this response to be short, it's just how I write. I used to consider tonal quality but gave it up when I retired.
Old 04-09-2013, 06:10 PM   #6
Phat Phrog Stunt Crew
awwall's Avatar
Here is Lipperts Maint. for their Jacks:
1. Change fluid in RESERVOIR ONLY every 36 months.
a) Check fluid only when jacks are fully retracted.
b) Always fill the reservoir with the jacks in the fully retracted position. Filling reservoir when jacks are extended will cause
reservoir to overflow into its compartment when jacks are retracted.
c) When checking fluid level, fluid should be within ľ” of fill spout lip.
2. Check the fluid level every month.
3. Inspect and clean all Pump Unit electrical connections every 12 months. If corrosion is evident, spray unit with WD-40 or equivalent
4. Remove dirt and road debris from jacks as needed.
WARNING!
Your coach should be supported at both front and rear axles with jack stands before working underneath.
Failure to do so may result in personal injury or death.
5. If jacks are down for extended periods, it is recommended to spray
exposed leveling jack rods with a silicone lubricant every seven days for
protection.
If your coach is located in a salty environment, it is
recommended to spray the rods every 2 to 3 days.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 04-10-2013, 10:20 AM   #7
Papi
Papicamper's Avatar
Thanks...Again...
for all the replies. The "winner" seems to be Wayne & Susan with his quotes from the manual. I really appreciate all the input. Now...going to buy some silicone.
Thanks Folks!
PapiCamper
Cedar Creek 36CKTS
Old 04-10-2013, 10:31 AM   #8
BoatDude's Avatar
Glad u found the info your looking for. When all else fails...read the manual....lol. I hope to get those books when they deliver our cc the 20th. Good luck.
2013 36 CKTS
ReTrax Pro Cover
Old 04-10-2013, 10:41 AM   #9
Former Full Timer
Duckogram's Avatar
Excellent conclusion Bill. However, there is no such thing as a "winner"or loser when it comes to sharing experience(s) and knowledge among
folks with a common interest. It's just folks trying to be helpful.
Old 04-10-2013, 06:59 PM   #10
Papi
Papicamper's Avatar
you're right!
Didn't mean to infer any reply was better than another...perhaps a poor choice of words. As I meant to say ALL replies are appreciated...there's no contest. Hope you understand. Always waiting for good ideas on forum...even have given out a few. Now...out to buy some silicone!
PapiCamper
Cedar Creek 36CKTS
