Old 11-15-2018, 10:06 PM   #1
Leveling
After camping for a few weeks is it ok to do a auto level again?
Richard B is offline   Reply With Quote
Old 11-15-2018, 11:09 PM   #2
Always Learning
Sure is. I personally would bring the slides in first.
Old 11-16-2018, 01:04 AM   #3
Coach
If you scroll through the auto level menu it will show how level you are side to side and front to back. If it's still reading 0 for both directions, I wouldn't probably bother releveling. I do agree though that it could be done any time but pull the slides in first.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 11-19-2018, 10:48 AM   #4
Jim34RL's Avatar
Do you have the Lippert Auto 6-point hydraulic leveling system? If so, just turn on your control display. Check to see if the green LED light in the center of the display panel is showing. If so, than the trailer is still level and you do not need to relevel. If one of the other lights is displayed such as to high or to low than yes you should relevel.
I have camped for several weeks at a time on the same site and I have never had to relevel my trailer. I have only releveled once when I raised the trailer to change out a tire at one of the F.R.O.G. rally's when I received a new tire and wheel from Forest River for my unit. I brought all of the slides in first and then relevel manually adjusting each set of legs to center the green light in the display.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 11-21-2018, 06:42 AM   #5
Green Horn
kevin211's Avatar
can you use the system to "lift" your Rv to change a flat tire.
kevin211 is offline   Reply With Quote
Old 11-21-2018, 06:54 AM   #6
"On the road again"
rjshiflet's Avatar
I wouldn't. Lippert and Forest River both advise against it.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 11-21-2018, 07:20 AM   #7
AquaMan's Avatar
I've seen Lippert and Forest River both do it!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 11-21-2018, 08:39 AM   #8
Yes, I lifted a side at a time to remove tires and have TPMS sensors installed. Since tires may be lifted off the ground during routine leveling on an uneven ground the recommendations against using the levelers for changing tires is purely a CYA by Lippert and FR from a safety standpoint.
cub22908 is offline   Reply With Quote
Old 11-21-2018, 09:04 AM   #9
NMWildcat's Avatar
X2. I've changed tires, due to flats or just changing to new tires, several times using the levelup jacks. One side at a time. Works great. I did put lynx blocks under the lifting side jacks to shorten the stroke.
Have also had one sides tires off the ground for weeks during boondocking trips.
My system is 7 years old this January and the levelup is still the best option on any RV
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 11-22-2018, 09:09 PM   #10
gkochel's Avatar
I think its a common thing to do and to be completely safe put jack stands under the axles after the unit has been elevated if you have the luxury of doing this at home. If on the road I would not hesitate to do it if on mostly level firm ground
2015 Cedar Creek 34RLSA Touring
2004 Silverado Duramax Crew Cab Dually
gkochel is offline   Reply With Quote
Old 11-26-2018, 09:04 AM   #11
Green Horn
kevin211's Avatar
Question for everyone, does anyone put boards under the jacks to give it a wider foot print? i'm thinking of doing this just so they wont sink into the ground and to give it more of a solid footing?
Any Thoughts on this or i'm I going over kill
Old 11-26-2018, 09:38 AM   #12
kinzoo's Avatar
All of the time....
kinzoo is offline   Reply With Quote
Old 11-26-2018, 09:39 AM   #13
kinzoo's Avatar
Keeps some of the dirt off the feet also.
Old 11-26-2018, 09:53 AM   #14
NMWildcat's Avatar
We replaced all our boards with lynx blocks when we purchased our current RV with the level up system.
Much easier to store and use. Lighter also. Not only do they provide a bigger footprint, but you can stack them under the jacks on the downhill side when needed. We found two sets of 10 (20 blocks) fits our needs.
Most RV parks also require some type of pad under the feet. Lynx blocks fills that bill also.
leveling
