12-03-2015, 10:47 PM
life expectancy of 12 v power supply
what is the life expectancy of an trailer 12 volt power supply?
12-03-2015, 10:49 PM
The converter?
Some last forever some don't make it a year.
12-04-2015, 12:27 AM
We had one that ran 5 years then replaced it and that one only lasted 6 months. TURBS said it all. Just like a battery...some run 5 years some short out after a month.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
12-04-2015, 06:33 PM
Good news is: when you NEED A BATTERY OR CONVERTER, you can generally pick one up at a Camping World same day. Of course, batteries are "everywhere" 😄.
12-04-2015, 06:36 PM
It will brake down when you are in the middle of no where!
12-04-2015, 10:05 PM
Get a good quality triple rate one when you replace it. I always install a Progressive Dynamics one with intelli charger pendant. I then use the old converter as a backup in case the new one fails. It never has!
01-14-2016, 01:34 PM
I plan to replace my 55amp converter with a Progressive Dynamics converter, I need help on choosing the right amp size. I have a bank of 4 6 volt batteries, do I need the 60amp, the 70amp or the 80amp. I seen on Amazon where the 80amp needs a special 20amp plug.
01-14-2016, 02:01 PM
The 80 amp does need a 20 amp outlet. This would mean changing the wire from the breaker to the converter and also changing the breaker from a 15 to 20 amp. I would go with the 70 amp converter.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
01-14-2016, 09:58 PM
converter Issues
Thanks for the reply.
We have 2008 Cedar Creek 32TK. This is second converter I have purchased. I went with a boondocker 60 amp. from Best Converter. I spoke with Randy about my power supply. He said I should get a surge protector. I got a portable 50 amp. Progressive surge protector. It cost more than Amazon but I got the latest model. Shown below is Randy's contract information.
Good luck with your converter purchase.
For free technical advice, orders or general questions call us at 888-828-1893. I'll pay for the call and we will do our best to answer your questions. You can also email us at sales@bestconverter.com for a prompt response. If your question is about an existing power converter, please have the make and model number so we can better assist in solving the problem or recommend the correct replacement unit. test model.
01-14-2016, 10:32 PM
From my experience, I don't think you can go wrong with any Progressive product. I have both the converter [replaced a WFCO] and transfer switch. No problems. We had a Progressive convert already in our last TT when we bought it and it was working fine when we sold it three years later.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
