Old 09-02-2016, 03:54 PM   #11
DKRITTER's Avatar
Originally Posted by btritschler1437 View Post
Per the Lippert rep at the FROG Rally the first thing you should do before you put down legs and/or roll out slides is to plug in the electric. Then unhitch, next set the front of the coach lower than the back.
This contradicts everything published by Lippert.
I have never plugged in before leveling.
Park the trailer, put down blocks, unlock trailer from hitch, deploy front legs and lift trailer off truck (puts the trailer in a nose high position), drive truck out and then hit auto level.
I unroll and test the power while the trailer is going through it's leveling process. It's always done long before I actually plug in. (Takes about 1 min to level and about 5 min to test electric.)
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is online now   Reply With Quote
Old 10-16-2016, 07:30 PM   #12
Witch Doctor's Avatar
I have a different problem my screen buttons work but I have no read out just a blank display anyone have this problem and how do I get the read out back? Thanks in advance, thought I try here before I call Lippert and they say buy a new controller for 260.00 bucks...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 10-16-2016, 08:01 PM   #13
wanderer69's Avatar
Had a similar issue. Called lippert support and they sent me a new at no charge. It was also out of warranty.
Tom
2015 Chevrolet Silverado LTZ 3500 CC DRW Diesel
2014 Cedar Creek 36CKTS
wanderer69 is offline   Reply With Quote
Old 10-17-2016, 02:59 AM   #14
Okay Thanks, I'll call in the AM and see what they say. It was weird I guess I was in the right mode, I raised the front to unhitch pulled away and just hit auto level and it did it normal thing then it beeped and the center green light came on then it shut off as normal. So the panel is working just a blank screen. Another weird story.... I'll post what happens, they told me they had a problem with the controllers but said I was lucky and got the new one when they installed it. Yea Right....I also unplugged the panel but still nothing on the screen after waiting 10 secs.
Old 10-17-2016, 12:15 PM   #15
Well I called Lippert today, had to get a display is what they told me, he asked what I did, I said I unplugged it waited 10 sec and still nothing then I pulled the fuse and waited then reinstalled still no display, so I had to buy a new display. If you look it up on line it say's the cost is 260.00 When I bought it direct they charged me 207.00. Either way I still would have to pay for shipping. we will see in a couple days if the LED displays comes back. It's like I told them all the buttons work but just don't know what mode it is in. I was lucky because it switches back to right mode when you raise the rams, so it worked to level but now you have to find retract to bring them up. PITA..and expensive..
Old 10-17-2016, 12:51 PM   #16
My controller looks like this. I can control everything without the display. When first powered up any button pushed will extend the ram selected. If you push the retract button in the bottom left corner any button will retract the ram selected. You just can't see for instance degree of level. This will get you set up or ready to leave.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 10-17-2016, 06:26 PM   #17
Yep that is the same one I have, I do understand what you are saying and thanks for taking the time to respond, that is what I did, I knew when the green light in the center was lite I knew I could go to auto level. I'm just upset that this controller did not last more then two years.
Old 11-14-2016, 09:04 AM   #18
TTanous - I just had the exact same thing happen. Did you get this resolved? I would love to learn from your experience. Thanks
btw - According to the Lippert documentation, Putting the nose low before pressing Autolevel is Wrong. It explicitly states to raise the nose above level before pressing Autolevel.
theczar is offline   Reply With Quote
Old 11-14-2016, 09:43 AM   #19
ttanous's Avatar
Theczar, I have not had any luck resolving. Removed power from the display also tried recalibration. Both produced the same issue. Now they want me to check the sensor behind the rear wheels which I believe will cause me to open the underbelly which I am unwilling to do because I don't think the sensor is loose when the right side works fine. Not impressed with their support at this time. I had not had a chance to troubleshoot more. Let me know what you try so I don't duplicate the effort.
ttanous is offline   Reply With Quote
Old 11-14-2016, 10:22 AM   #20
Mddle of the Rd Extremist
MeepMeep's Avatar
Originally Posted by ttanous View Post
Took the CC out today and had a problem we have never had. Lifted off the truck first. Pulled the truck out the hit auto level. Front adjusted to what appears leveling front to back. Street side leveler middle went down about 3 inches and stopped. The curb side levelers both middle and back went all the way down then lifted. Front levelers adjusted then curb side adjusted and then sounded it was level. Check the screen and it was level side to side and front to back. I had to manually lower the street side levelers middle and back. Any ideas on why this happens? Tried several times with the same results. Does the system need a reset? Not an issue for this trip but will be putting it back in the storage building so wanted to see if there is something I should try.
Tom
2016 Ford Power Stroke F350 Lariat Crew Cab Long Bed Dual Wheel
2015 Cedar Creek 38RD Hathaway Edition
Did you try leveling manually, then re-setting the zero calibration? If the auto level hasn't been properly calibrated to zero, then it will set to a false level until it's recalibrated......learned from having the same symptoms
Good luck!
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
