Old 09-01-2016, 10:42 PM   #1
ttanous's Avatar
Lippert Level Up System Issue
Took the CC out today and had a problem we have never had. Lifted off the truck first. Pulled the truck out the hit auto level. Front adjusted to what appears leveling front to back. Street side leveler middle went down about 3 inches and stopped. The curb side levelers both middle and back went all the way down then lifted. Front levelers adjusted then curb side adjusted and then sounded it was level. Check the screen and it was level side to side and front to back. I had to manually lower the street side levelers middle and back. Any ideas on why this happens? Tried several times with the same results. Does the system need a reset? Not an issue for this trip but will be putting it back in the storage building so wanted to see if there is something I should try.
Tom
2016 Ford Power Stroke F350 Lariat Crew Cab Long Bed Dual Wheel
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 09-01-2016, 11:03 PM   #2
Yea, that is very strange. The system usually puts down the jacks on the low side first, in your case curb side, but it started on the high side then stopped.
I have never had that happen and not sure if you recalibrate that that will fix it as it completed level even though one side was not touching the ground.
You said you tried it several times with the same result. Did you try turning the system completely off and back on? I also assume you started the whole process with the front higher than the back?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 09-01-2016, 11:15 PM   #3
ttanous's Avatar
Yes actually turned off and back on at the panel and tried gain. We actually had to move due to a breaker supporting several sites was not holding yes this problem existed before we ever hooked up to shore power. So moving and unhitching again produced the same problem. Will call lippert in the morning to see they have any ideas.
Tom
Old 09-01-2016, 11:58 PM   #4
dieselguy's Avatar
Try turning system off and removing the wiring connector from the back of the touch pad for 10 seconds, then plug it back in. You may have to manually level your fiver and store that back in the memory. Once leveled press front button 10 times then press rear button 10 times ... you should see zero point successful with in a few seconds.
dieselguy is offline   Reply With Quote
Old 09-02-2016, 07:30 AM   #5
Odd. The system is supposed to do front/left/right/front. The left/right bit is supposed to stop when it senses movement or the unit is levelled side to side. It may be possible that the rear sensor thought there was movement or the controller figured the unit was levelled.
In any case, I agree that the system needs to be reset. To do that, you have to remove power to the leveling control for ten seconds. You can open the breaker that powers the system, pull the fuse that feeds the controller, or unplug the connector to the controller that has the red power wire.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 09-02-2016, 01:02 PM   #6
btritschler1437's Avatar
Per the Lippert rep at the FROG Rally the first thing you should do before you put down legs and/or roll out slides is to plug in the electric. Then unhitch, next set the front of the coach lower than the back. Start the auto level process, you may even see the coach go into a kneeling position, then it brings the front up and lowers the other four legs. Once auto level is complete, roll out your slides. They want the coach to be level and supported so the slide openings are square and will not bind as the slide comes out. Also if you have a Schwintek slide, be sure to hold the button in till the motors have stopped running. Usually about 7 to 9 seconds, you will not burn out the motors by holding the button in, but will allow the motors to resync themselves, since the system counts the revolutions each motor makes.
Bob & Sharon, "15 Cedar Creek 38CK Custom, '13 RAM 3500 Laramie, 4x4, LB, CC, DRW 6.7 Cummins HO, Aisin 4.10"
btritschler1437 is offline   Reply With Quote
Old 09-02-2016, 01:30 PM   #7
dieselguy's Avatar
I guess the rep never boondocks ... there's noting to plug electric in to. I was always told to have the nose high before pressing auto level. I do agree about leveling before deploying the slides.
Old 09-02-2016, 02:14 PM   #8
TURBS's Avatar
It doesn't matter nose high or low it will find level.
Shore power also has zilch to do with leveling unless the battery is low
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 09-02-2016, 03:24 PM   #9
Narborza is correct the leveling sequence is
Auto Level Sequence
1. Front landing gear retract, lowering the front of the unit below level, stopping, then lifting the front end to level the unit front to back. (Fig. 4A).
2. The left side leveling jack(s) extend and raise the roadside of the unit (Fig. 4B).
3. The right side leveling jack(s) extend and raise the curbside of the unit, beginning side to side leveling (Fig. 4C).
4. The front landing gears extend to complete the leveling cycle (Fig. 4A).
Step 2 will always raise the roadside even if it is high to begin. As long as there is 12.7 volts it should work, you do not need shore power. Lastly turning power off and on does not reset the controller, you must remove 12 volts from the controller. It is the plug with one single red wire.
I have found pulling the red wire plug fixes many weird problems. My battery disconnect switch does not remove power to my level up it would have been easy to reset
If you pull power you do not loose the "level setting"
denville is offline   Reply With Quote
Old 09-02-2016, 03:27 PM   #10
Go to the App Store and get the myLCI app it has great information and diagrams on the level up system
