06-15-2017, 07:37 AM
Lippert Leveling Jacks make popping noice
We have a 2014 CKTS and have been living in it for three years. Lately we hear lots of popping noice coming from the jacks. Anyone else have this problem?
06-15-2017, 08:16 AM
Not enough info.
When does it occur, how long does it last, have you checked the fluid level recently, look at the pads and legs, so they have fluid on them?
Don
US Army Infantry Retired
Texas Hill Country
Cedar Creek Silverback 29RE
'19 F 350 CC, LB King Ranch Ultimate
06-15-2017, 08:29 AM
Originally Posted by 17 Oaks
Not enough info.
No leaks, and had enough fluid! I hear it everyday with today being the most noice. Never had this issue before.
06-15-2017, 09:26 AM
Does it do it on the up, down or level out?
Popping noise generally indicates a loose connection/fitting, screw loose or missing allowing movement. I have heard that sound from Corvettes to John Deere's, Harley's to bicycles.
Don
Texas Hill Country
06-15-2017, 09:35 AM
Very common issue with the Lippert leveling jacks. Mine have done it for the past 2 seasons. I added the anti-stiction fluid this year as recommended by lippert and I haven't heard a single noise from them since. I recommend going with the CAT 1U-9891 fluid, a buddy of mine used the other stuff listed on the service advisory and it didn't work. See link below:
https://www.lci1.com/images/support/lipsheet/0295.pdf
2016 FR XLR Thunderbolt 395AMP
2015 Ford F350 CC SB 4x4
06-15-2017, 12:40 PM
The jacks on my Trilogy do the same thing. Added the anti-stiction fluid, really no help. We have learned to live with it. Been three years...
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
06-15-2017, 01:18 PM
John, did you use the CAT fluid of one of the other 2 on the list?
06-15-2017, 01:34 PM
I had this, also. I applied silicone with teflon liquid all the way from the top of the legs and let it run down the legs. Since I did that, the popping has become a whole lot less. There is still some ratcheting noise coming from the axles, while the trailer is going up and down. However, the "popping" noise from the leveling system is a lot less.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
06-15-2017, 02:44 PM
I used one from the Lippert list.
John
06-15-2017, 03:08 PM
John
The 2 fork fluids that they have listed do not work to solve the popping noise. The CAT hydraulic additive does work, it's a little bit more expensive and can only be found at a CAT dealer.
06-15-2017, 10:35 PM
Dahagen
Use the Cat stuff. It works! $35+ per quart but you only need one.
06-16-2017, 03:12 PM
Ok, I appreciate the advice! Thanks!
06-17-2017, 06:30 PM
I'll have to disagree with you CAT enthusiast about it being the ONLY oil to go with ... I used the Torco RFF 15W with success. Don't just remove fluid and dump the new in ... follow Lippert instructions.
http://www.lci1.com/images/support/lipsheet/0295.pdf
06-17-2017, 07:54 PM
And if you still have noise after the fluid "treatment", get rubber jack pads, that is what finally got us a quiet night's sleep, after two fluid replacements. In deference to a previous poster, I don't think we used Cat, however.
06-17-2017, 09:20 PM
Originally Posted by dieselguy
I saved the instructions, thanks. I did realize that one side of the rig was actually off the ground only being held by jacks. Since then it's been a lot better.
