Originally Posted by radio flyer
I have a 2018 Cedar Creek 34RE with this problem. Is this covered under warranty to add the anti-stiction fluid, as per Lippert's notice #0295.
Has this procedure fixed the problem?
Yes, eliminated the popping noise in my system. Under warranty, i doubt it. Easy DIY task. Purchase a small hand pump from Harbor Freight, Walmart or auto parts store to remove 1 quart of fluid. Follow Lipperts guidelines on adding the fluid. Occasionally a second quart may be needed if the popping continues.
