Old 11-02-2013, 01:39 PM   #1
Living room TV
I must be doing something wrong, in my living room Jenson TV I can only recive about 15 channels and they go in and out but the bedroom Jenson TV I can pick up at least 50 channels and they are clear. What could be wrong, the TV boster is on
spock123 is offline   Reply With Quote
Old 11-02-2013, 01:45 PM   #2
Carknocker Family
Ida Ratherbe Camping's Avatar
just a guess, but do you have LED lights? Have heard that they will mess with the reception of TV
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 11-02-2013, 07:14 PM   #3
I don't think so about the LED lights, I had LED lights on my Wildcat Sterling and I had no problems with the TV
Old 11-02-2013, 07:42 PM   #4
Former Full Timer
Duckogram's Avatar
try checking the coax connectors on both ends. if they are good, you might need to pull the plate with the amp and check the connectors on the back. the satellite and TV may be reversed. I will assume you ran set up channel search on air setting.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 11-02-2013, 08:11 PM   #5
When I first got camper my Tailgater would not work in the camper, Tom Johnson changed something and the Tailgater worked, then I could not get cable to work.
Camping World fixed that. Now the TV does not pick up all the channels in the living room, the bedroom TV works great. I have pulled the plate off and I am not going in there, I guess I will have to take camper back to Camping World, at Tom Johnson all you can get is one PBS station. I may wait until I change the TV from the side to the rear to get everything fixed. DW likes cable and satellite, not much for antenna. I do a channel search everytime i move camper
Old 11-02-2013, 08:13 PM   #6
Carknocker Family
My cables were reversed in my TT also.
2017 Ram 2500
2014 Salem 32BHDS
Old 11-02-2013, 09:18 PM   #7
Former Full Timer
Duckogram's Avatar
That's fantastic.
roo
