Old 07-01-2015, 08:10 PM   #31
Blackhat6mike's Avatar
Question for DRW owners. Is the rear tire life any better with duals? What about gas mileage difference? My SRW Silverado Duramax is all I need for now, but never know if I'm going with a bigger TT. I've been known to change my mind before....
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 07-01-2015, 08:13 PM   #32
jtstromsburg's Avatar
Too soon to know for sure, but compared to my old f250, the tires aren't wearing at all. My sabre ate the tires off the rear of that truck in 15000 miles and they were E rated Firestone's.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-01-2015, 08:29 PM   #33
ttanous's Avatar
I have owned 2 3500 Chevys drw duramax's and went to a 3500 duramax srw. I have not seen any difference and like the narrower rear end. The srw is just as stable a platform as the drw from my experience. Pulling a CC 38rd 42 feet with no problems.
ttanous is offline   Reply With Quote
Old 07-02-2015, 04:58 PM   #34
Went from a F350 SRW 6.0 to a GMC 3500 DRW 6.6 and wow what a difference in handling. Yes it maybe a couple feet longer and wider but I have yet to not find a place to park him. Will never go back to a SRW.
Sierra360PDEK is offline   Reply With Quote
Old 07-02-2015, 05:12 PM   #35
Think it's really fair to compare the ford to a GMC? I mean, come on. . Love my GMC 3500 drw!!
Joel and Teresa
2016 Sabre 34TBOK
Old 07-02-2015, 06:22 PM   #36
A DRW gives you more stability but a lower towing capacity. Unhooked it is a limiting factor in the city.
The primary difference between the 3/4 and 1 tons is the rear suspension. I know the Ford 250 and 350 are largely identical. Ask most truck owners what is best and they will tell you it is what they are driving. That is a good thing since it means they are satisfied.
I have a 3/4 ton Ford 250 Diesel SRWand love it. Lots of power for my Silverback 31 RK. 100k power train warranty. Happy camper.
Brentf is offline   Reply With Quote
Old 07-02-2015, 07:17 PM   #37
ferguson65's Avatar
I love my dually. My trailer doesn't really require it, but I'd rather have plenty of capacity rather than run tires close to max. I was back and forth before I ordered the truck, and once I priced both out the SRW and dually, the dually cost about $1,000 less. Same options, more capacity and less money was a no brainer. The Ford SRWs sit so high in the back also and that was a consideration too. I have my Reese Elite set to the factory position, and the trailer pin box in the factory position, have 8-9 inches bed clearance and the trailer rides level. I've seen the trailer come close enough to the bedrails as it is. I also use the bed of the truck and climb in and out quite a bit so 4" lower is great.
Would a SRW truck do the job? Yes. Would it be easier to park? Doubtful, as Ependydad pointed out it's not the width, it's the length that gets you. My truck is every bit of 24' long. But so is a CCLB SRW. Width is a factor but it's very minor. One big thing to learn if you don't already know is never, ever, pull into a parking spot, that's how you get stuck with these monsters. Some campgrounds it sure would be nice to have a short truck to get the trailer in and out, but out on the road, I'll keep my LWB.
As an aside, there is no new option for a shortbed dually, aside from a megacab Ram, but given the cab size I don't know that the truck is really any shorter overall than CCLB. GM hasn't built one since the late 90's, and Ford's short run of them ended in 2010.
I'd buy the dually.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 07-02-2015, 07:56 PM   #38
B and B's Avatar
I just bought my F 250 SRW with a Supercab. Wanted a short truck for daily driver. This is the same length as the F 150 i traded but the wheelbase is 3 inches shorter. I have plenty of capacity for future upgraded. There are 2 of us, a little dog. We don't need the crew or the loss of CCC it brings, a 6 3/4 ft box, 4 wheel drive definitely as well, never owned a trucks without it. I have the stability, unrivalled power stroke torque and horsepower and exhaust brake.
Enough truck for what we need for a trailer.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-02-2015, 11:04 PM   #39
I went from a 2010 Dodge short box swr to a 2015 Silverado dually. all I can say is WOW! This the real deal. Wish I had listened to my friend sooner. Go dually you won't be sorry.
GOTTOYS is offline   Reply With Quote
Old 07-03-2015, 06:41 AM   #40
B and B
Precisely! Exactly WHY so many build variations.
As previously posted, each personal towing adjustable weight is individually selected when loading.
Adjustable meaning what I choose to carry in my truck bed ( a 40 pound bicycle ) minus a 60 pound plus tail gate ( I use an 8 pound metal mesh gate which locks in ) and then low tank levels in the RV and weight distributed accordingly.
Towed x USA AND BACK, up hills, down hills, heavy storms in Amarillo,
dust storms with low visibility, etc.
NEVER once any RV or truck concerns except weather. I travel at 62 mph on all major highways and it is sooooo relaxing and enjoyable travel. 🏁
SilverbackMel is offline   Reply With Quote
truck
