Old 01-06-2016, 11:15 AM   #11
dieselguy's Avatar
I guess I'm used to my old SOB's (Montana's) they had a backflow preventer in one line right off the W/H. You would not drain the W/H via low points faucet open or not on them.
dieselguy is offline   Reply With Quote
Old 01-06-2016, 12:03 PM   #12
robert.beck.7737's Avatar
Low Point Drains
Exactly what do the low point drains do. Is this all you have to drain to winterize your RV or do you still need to pump RV antifreeze or blowout the system? I know you have to put antifreeze in the P traps
robert.beck.7737 is offline   Reply With Quote
Old 01-06-2016, 12:57 PM   #13
BillyBass's Avatar
I still have antifreeze in my low point drains since I bought it new 2011 never drain them. I don't know what you guys talking about with the wh and lp drains
But when i drain the heater I take a wet vac and I stick a small flex hose on the end and suck out the crud then leave it open. It explain to me what there propose are for
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 01-06-2016, 01:50 PM   #14
The lowpoint drains are literally the lowest point in your RV's plumbing system. Once you drain your WH, you should be able to get any remaining water out by opening them up.
As far as winterizing with AF, you'll get mixed opinions on that. Most everyone blows out their lines with air. Some *only* add to traps and toilets. Others pump AF throughout. It's really your personal preference.
Iwritecode is offline   Reply With Quote
Old 01-06-2016, 02:11 PM   #15
Indymule's Avatar
If you don't have to winterize and you don't need to drain the water lines then this is not a problem. If you have been using the water in your trailer, you no longer have antifreeze in the lines. The low point (lp) drains are just what was said, the lowest point of the water lines and the easiest way to drain the water out of the lines. If you don't drain the water heater or isolate the water heater before you open the lp drains, it will draw the water out of water tank (and any sediment).
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
2017 Ford F350 Crewcab Dually Diesel
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 01-06-2016, 03:11 PM   #16
BobHanke's Avatar
Make sure your rig is level or the low points are indeed the lowest to empty properly. By pass the hot water heater BEFORE adding antifreeze or you will use an unnecessary 6-10 gallons more.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = Shikibu
BobHanke is offline   Reply With Quote
Old 01-07-2016, 11:56 AM   #17
dieselguy's Avatar
If you've ever pulled panels in your storage compartment or been inside the underbelly above the astrofoil and batt insulation, you'll find there's just too many jogs and didos in your plumbing to depend on the low point drains to dependably winterize your unit. They are not the absolute lowest point in the entire plumbing run. Yes they drain most of the water, but always go ahead and blow out your lines or add "pink stuff" as it's just the smart thing to do.
Old 01-07-2016, 11:10 PM   #18
steelpony5555's Avatar
Ok what I meant was if I opened the low point drains would that also drain the water heater...I was not thinking of the crud in the tank so won't be relying on that. I concur with Dieselguy, there are way too many dipsy doos in the plumbing to rely on the low point drains to get all the water out...would take just one dip in the line to have a big leak in the spring... Now here in Texas would that happen?? I don't know but don't want to find out. So I at least blow out with air. and will remove the plug in the water heater for sure....Thanks
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 01-08-2016, 06:40 AM   #19
Mr. Dan's Avatar
Yes, it could happen in Texas. I lost a toilet valve in an older trailer because I failed to hold it open when we were blowing out our lines. The trailer was 60 miles north of Dallas.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 01-08-2016, 08:52 AM   #20
Yes, but you are in the Tundra area of Texas......lol lol lol
From Central Texas
drain
