Old 03-09-2014, 02:52 PM   #11
NELA
Weezer's Avatar
Originally Posted by gljurczyk View Post
They have just installed 2 shut off valves in my basement for the low point drains. If you get into cold weather as I did in Pensacola Fl. a couple of weeks ago they both froze and caused a leak. That is the weak point of the whole system. I hope I hit all the right keys this time Weezer?.......
LOL,
We wrap out LPDs with "RubberTex" during cold weather. (throw back to A/C dealership days....it was used on Freon lines.)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 03-10-2014, 06:06 AM   #12
Oakman's Avatar
Originally Posted by ret2006 View Post
My CC 34 RLSA just has caps on low point drains.
What? I guess CC went on the cheap for 2014.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-15-2014, 02:29 PM   #13
Mine has caps on them as well. However, they are very difficult to remove.
On the other hand, I find that the receiver they screw into is *much* easier to turn and let's me loosen the cap.
Keith & Liz
2010 SilverBack 33L
2009 F-250
kablair is offline   Reply With Quote
Old 03-16-2014, 09:43 AM   #14
You were right. It's behind the side wall in the garage. King nice this way. Other trailer had the caps at the ends and sometimes we're hard to get to. This seems much easier
Truck: 2015 F350 Platinum
Trailer: 2013 Cedar Creek 36CKTS
spawnman is offline   Reply With Quote
Old 03-16-2014, 10:11 AM   #15
Witch Doctor's Avatar
The good thing about a shut off valve in the basement, They won't freeze up, or you do not have to insulate the bottoms so they don't freeze up when your camping. They should put in shut off valves on units for as cheap as they are. It just nickel and dime stuff.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-16-2014, 10:21 AM   #16
NELA
Weezer's Avatar
Can you post a picture of the valves you installed....please?
Old 03-16-2014, 10:25 AM   #17
Sure Weezer I will try it might behard to see because of the water pump, give me a few minutes.
Old 03-16-2014, 10:41 AM   #18
Here they are the round flat ones, the other is the joint that we put in to pull the lines to install couplers otherwise you couldn't do it without pulling the water pump.
Old 03-16-2014, 10:45 AM   #19
joint where the plex was cut to make easier to pull to install right before the 90 degree drop down outside
Old 03-16-2014, 10:45 AM   #20
48fan's Avatar
Originally Posted by cpaulsen View Post
They should have caps on them. I pulled my caps off and used a 1/2" pvc valve to replace the caps.
x2
2014 coachmen clipper 15RB
2000 ford f-150 super cab 4.2 6 cyl
48fan is offline   Reply With Quote
drain
