03-08-2014, 11:00 PM
Low point drains
So I have a brand-new 2013 Cedarcreek 36CKTS. I see where the low point drain is but I don't see any valves to open them up. Can anyone tell me what I'm missing here?
Greg
Truck: 2015 F350 Platinum
Trailer: 2013 Cedar Creek 36CKTS
03-08-2014, 11:06 PM
Carknocker Family
Mine just have caps on them. Just unscrew them and let the water out. then if they do not have a rubber gasket in them, Teflon tape them.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
03-08-2014, 11:17 PM
NELA
Ditto
I'm assuming the OP means the Red and Blue low point drain lines.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
03-09-2014, 01:12 AM
Old Member
Look in the RH basement behind the sliding panel, there are two valves there ( hot n cold)
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
03-09-2014, 05:18 AM
Click on this link http://www.forestriverforums.com/for...nes-49633.html and then scroll down to post number 7 to see the photos I posted of where the low point drain valves are hidden.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
03-09-2014, 07:28 AM
They should have caps on them. I pulled my caps off and used a 1/2" pvc valve to replace the caps.
03-09-2014, 07:54 AM
No caps on Cedar Creek models, there are actual open/close valves on the lines in the basement area.
Sent from my NX008HD8G using Forest River Forums mobile app
Bob and Joyce
ATU Local 788
03-09-2014, 01:46 PM
My CC 34 RLSA just has caps on low point drains.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
03-09-2014, 01:49 PM
The drain for my fresh water tank is like that, good thing the water is low volume.
03-09-2014, 02:02 PM
Originally Posted by Weezer
Ditto
They have just installed 2 shut off valves in my basement for the low point drains. If you get into cold weather as I did in Pensacola Fl. a couple of weeks ago they both froze and caused a leak. That is the weak point of the whole system. I hope I hit all the right keys this time Weezer?.......
Coachmen M/H
Concord
2018 / 300 DSC
03-09-2014, 02:52 PM
NELA
LOL,
We wrap out LPDs with "RubberTex" during cold weather. (throw back to A/C dealership days....it was used on Freon lines.)
03-10-2014, 06:06 AM
What? I guess CC went on the cheap for 2014.
Bob and Joyce
ATU Local 788
03-15-2014, 02:29 PM
Mine has caps on them as well. However, they are very difficult to remove.
On the other hand, I find that the receiver they screw into is *much* easier to turn and let's me loosen the cap.
Keith & Liz
2010 SilverBack 33L
2009 F-250
03-16-2014, 09:43 AM
You were right. It's behind the side wall in the garage. King nice this way. Other trailer had the caps at the ends and sometimes we're hard to get to. This seems much easier
03-16-2014, 10:11 AM
The good thing about a shut off valve in the basement, They won't freeze up, or you do not have to insulate the bottoms so they don't freeze up when your camping. They should put in shut off valves on units for as cheap as they are. It just nickel and dime stuff.
Coachmen M/H
Concord
2018 / 300 DSC
03-16-2014, 10:21 AM
NELA
Can you post a picture of the valves you installed....please?
03-16-2014, 10:25 AM
Sure Weezer I will try it might behard to see because of the water pump, give me a few minutes.
Coachmen M/H
Concord
2018 / 300 DSC
03-16-2014, 10:41 AM
Here they are the round flat ones, the other is the joint that we put in to pull the lines to install couplers otherwise you couldn't do it without pulling the water pump.
Coachmen M/H
Concord
2018 / 300 DSC
03-16-2014, 10:45 AM
joint where the plex was cut to make easier to pull to install right before the 90 degree drop down outside
Coachmen M/H
Concord
2018 / 300 DSC
Racin
x2
2014 coachmen clipper 15RB
2000 ford f-150 super cab 4.2 6 cyl
