Old 05-13-2015, 10:52 AM   #101
Commercial Member
Originally Posted by toslow View Post
the tires i got new are 235/80/16 load range is E
the tiers that came on the trailer are 235/85/16
Interesting. I am having problems finding either size in the truck or bus tire section of Tire & Rim Association yearbook.
I do find ST235/85R16 LR-E in Special Trailer section rated at 3,640# @ 80 psi
and I do find an LT235/85R16 LR-E in Light Truck section rated at 3.415# @ 80
Could yo let us know what brand tires and where you found the 235/80R16 LR-E
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 05-13-2015, 05:55 PM   #102
toslow's Avatar
goodyear marathon, i got them from cerka trailer supply in milton ontario
http://www.amazon.com/ST235-GOODYEAR.../dp/B006UH6KGU
these are the tires i bought
haven a blast
toslow is offline   Reply With Quote
Old 05-13-2015, 09:44 PM   #103
Commercial Member
Amazon.com: ST235/80R16 GOODYEAR MARATHON Radial Trailer Tire, Load Range E: Automotive
OK So the tires were not 235/85R16 and 235/80R16 but actually ST235/85R16 LR-E and ST235/80R16 LR-E
It really does make a difference to know what the tire size really is when discussing changing tires and confirming load capacity.
Given this thread topic was LT vs ST and not commercial sizes I think you can understand my confusion.
Old 05-14-2015, 04:41 PM   #104
toslow's Avatar
it probably is my fault, i'm sorry if i didn't explain myself clearly. the tires on the trailer now are LT235/85/16 . they are an "all country"
but you being a tireman, do you think i'll be ok with the change?
haven a blast
Old 05-21-2015, 12:07 PM   #105
Blackhat6mike's Avatar
Another recall on China Bombs. Recall notice from NHTSA's Office of Defects Investigation. 15T009
NHTSA Campaign ID Number : 15T009
Synopsis : Shandong Jinyu Industrial Co. LTD, (Shandong) is recalling certain Jinyu YS78 and Evergreen ES89 AT tires, size LT225/75R16, manufactured April 1, 2011, to August 31, 2014 (DOT date codes 1611 through 4314). The affected tires may not be able to properly dissipate heat, and as a result, the tire belts may separate. If the tire belts separate, the tire may suddenly lose air, increasing the risk of a crash. The remedy for this recall is still under development. The manufacturer has not yet provided a notification schedule. Owners may contact Shandong customer service at 1-786-521-1296.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
