Old 02-27-2016, 07:03 PM   #11
SilhouettePenny's Avatar
We've had several discussions about the goofy kitchen range hood flapper. When you get fed up with the hassle think about replacing it with a Sam-1 Range Hood Upgrade. Then you can open / close the vent from inside the camper. And its' squirrel cage design is both quiet & effecient, compared to the three blade plastic rattling fan.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 02-27-2016, 07:52 PM   #12
VinceU's Avatar
Originally Posted by Scheinin View Post
I am spending my first week in my 2016 36ckts. I seem to be having fan issues. When I turn on the microwave exhaust fan, most of the air blows into the kitchen rather than outside. I asked the dealer tech about this, and he told me that I have to open the outside vent, which is high up on the unit. I got a ladder to reach the vent, but it does not appear to have a mechanism to open any further. In looking in the microwave manual, it only references that the installer should make sure the vent flap moves freely. To me this means the outside vent does not open, but there is a flap that should open automatically in the unit. Can others with the Whirlpool microwave in the 36ckts tell me how their fan operates? Thank you.
I think I can offer some advice on the subject. First microwaves usually are furnished with a "baffle" that is adjusted before its lifted into position. Most all units have it because in "Position A" it's set to recirc the vent air through a washable filter and back to the room. In "Position B" all air is directed through the back and upwards, connected to a duct and directed outside. This is for homes as well as RV's. Secondly I had a RV that had an additional flap or door within the vent hood. It used a sheet metal handle to remove a pin which locked the door closed. When slid out the handle would move to unlock a sheet metal flap to the outside. There another door with two latches locked a rectangular door on the outside as yours. That door would open at least 2" on a hinge setup. So you can see at least three blocks to the air flow. Best test, you should feed good air flow outside when its running. Leave removing the M/W to the dealer if it must be dropped to adjust the baffle. Its under warranty.
Old 02-27-2016, 08:38 PM   #13
When I dropped my microwave I did not see a baffle, what there was a fan that you can turn around and blow the air out the back though the vent. I checked one at Lowes and the air came out the front, I think all the microwaves are about the same. I have looked at different brands and at least the ones I looked at had a motor and fan at the back and if you wanted the air to come out the front or back was how the motor and fan was set. This is a above the range microwave.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
fan
