Old 04-23-2013, 09:03 PM   #1
mike2wheels's Avatar
Missing label on hydraulic valves
We have a 2013 Silverback 35FL with 3 hydraulic slides (and 1 electric, but that's not the problem). It's missing the label that would normally be above the 3 valve manifold found in the front compartment. I believe these valves control the operation of the individual slides. I realize that it's possible that my manifold isn't "wired" the same as yours, but could someone please tell me what your label says?
Thank you.
2005 Honda Gold Wing
2010 Dodge 3500 SRW
2013 Cedar Creek Silverback 35FL
mike2wheels is offline   Reply With Quote
Old 04-23-2013, 09:51 PM   #2
Former Full Timer
Duckogram's Avatar
If you turn all but one knob 90* clockwise then activate the pump, only one slide will move. Do that with the other 2 one at a time and you will know for sure. Then it's label maker time or you can ask CC to send you some. Mine read Bdrm Main and ODS but your slides are very different. Hope this helps.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 04-24-2013, 11:09 AM   #3
Our 38FL label. Main label is front of rig.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-24-2013, 06:38 PM   #4
Thank you for your replies and photo. That's what I was looking for.
2010 Dodge 3500 SRW
