Old 04-17-2013, 09:52 AM   #1
Model of Cedar Creek TrailAir Air Ride Pin Box
We have a Cedar Creek on order that will have the TrailAir Air Ride Hitch Coupler installed. We need to get the Model Forest River installs.
It should be either Standard Air Ride or Tri-Glide.
The hitch we plan on using will not support the Tri-Glide so we are hoping for the Standard model.
Cannot find any contact information to ask Cedar Creek so asking owners for help. Please respond if you own a late model Cedar Creek with the TrailAir factory installed.
Thanks, we appreciate your assistance,
Jim
UncleFudd is offline   Reply With Quote
Old 04-17-2013, 10:13 AM   #2
Former Full Timer
Duckogram's Avatar
Since you did not specify what model you are getting, all I can say that the 36 Series has the TrailAir L-05 option and the TriGlide add on option if you specifically asked for it. Its at least a few hundred bucks more so you should know. You can call Justin Day at Cedar Creek, 260-593-2598 and ask him but your dealer should be your first point of contact.
What kind of hitch is not compatible with the TriGlide other than auto sliders?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 04-17-2013, 10:19 AM   #3
Agree with what was said... unless you specified the Tri-Glide it would unlikely be included due to the added cost. But check your dealer and build sheets.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-17-2013, 11:17 AM   #4
Campingnut's Avatar
When I ordered my CC they would not put on a Tri-glide so I would also assume that it would be just the standard Trailair.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 04-17-2013, 01:15 PM   #5
Sorry, the Cedar Creek ordered is 36CKTS.
We checked TrailAir Air Ride Hitch Coupler on the Options Sheet.
The price listed is $863. No mention was made about a Tri-Glide.
Thanks for all the responses. If this info changes your response please reply.
Due to the hitch we plan to use not supporting the Tri-Glide it is important that we know what we are getting. We did call Cedar Creek and could not get answer, even the Parts Dept did not know.
Thanks so much for your help,
Jim
Old 04-17-2013, 01:50 PM   #6
How much difference is there between the Tri-Glide and standard Trailair?
Is it worth the extra cost?
sidney is offline   Reply With Quote
Old 04-17-2013, 01:55 PM   #7
Average - $825 for a TrailAir - $1300 for a TriGlide
Walter & Donna
Old 04-17-2013, 01:57 PM   #8
What about the actual performance? How much better is the ride with the Tri-Glide?
Old 04-17-2013, 02:22 PM   #9
We bought a 2013 Cedar Creek 36CKTS with the trailair hitch option. The option cost was $863 and it was just the trailair and not the triglide. It is a pretty safe bet that what you are getting is just trailair.
2008 F350 DRW CC Lariat, Reese 18K
2013 CC 36CKTS
Me and DW
MDCRAB is offline   Reply With Quote
Old 04-17-2013, 06:24 PM   #10
Former Full Timer
Duckogram's Avatar
The folks that I know are using the TriGlide
to eliminate "chucking". If you get a lot of chucking with your hitch then you might want to spend the bucks. I do not experience chucking so no TriGlide for me.
