06-21-2018, 03:35 PM
More Slide Problems
Just home from long trip to Yellowstone, Utah, etc etc etc............
After living 14 months with slides that wouldn't go in, wouldn't stay in, and getting them fixed at Orvan's last August.........I was happy. TILL this trip. First, slides are beginning to not go in at times. Level Up system goes through Leveling process and says "Success" then I see only 3 of the 4 rear jacks are down......(this is at level concrete sites).
That's the minor issue.
Big creaking noise, and dinette slide floor is destroyed. Slide runner on edge is in tatters, and the floor laminated plywood is coming apart. Obvious water damage. Just POP, showed up.
After limping around, I finally duct taped it and brought that slide in, shut off that valve, and stuck a Slide Stopper in it. There it will stay until I can get back to Orvan's.
The good news? Called Orvan. He called me back almost in tears. He said he's ready to pull his hair out. I told him his hair was too curly to bother with, just help me pull MINE out.
He moved me up to July 9-10. So, to Indiana I go.................and I believe he'll fix it, and I believe Cedar Creek will stand by it.
But I'm pretty frustrated.
FROG AR-0019-242
06-22-2018, 04:33 PM
Doesn't fate know you guys are too nice to have this happen?!!
Good luck... Although you shouldn't need it with Orvan at the wheel.
06-23-2018, 10:29 AM
What a bummer.
On mine, rain water runs off the dining room slide-out topper on the right side and runs down the window and wall (nearest the entry door). I think your first picture is that same slide-out wall. I wonder about that increasing the chance of water getting in and causing damage.
Does yours do that?
The awning width is a few inches short (compared to the others) because the patio awning is in the way.
Let us know more after Orvan fixes it.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS, Disc Brakes
06-24-2018, 09:53 AM
Yeah, I've thought of that. I am withholding real comment until Orvan looks at it. But yes, when it rains with slides out, and then I bring slide in (back when it would GO in!! LOL), rain water POURS down!
But that shouldn't be an issue IF it was caulked right. If you look in the first picture, there's a trim piece. I took that off to duct tape it all up. But that trim piece had the most minimal of caulking. Certainly not good GeoCell caulk all up and down it.
SO.......I'm thinking that even if our source of water is what you say, that wouldn't get into the floor IF it was caulked properly.
Makes me mad.............last winter I had a leak where the gutter pieces meet (there's a seam, the gutter is not continuous for 40 feet), and it took forever to find it. When I was looking for the leak, I caulked every dang thing I could find. BUT NOT THAT trim piece! I bet damage was already done, but that would have helped I think.
I will report back what Orvan finds. Man, I'm bummed......I'll just tell you.
FROG AR-0019-242
06-24-2018, 06:26 PM
So sorry. I follow you guys and seems like you are on the road a lot.
Hope it is fixed and stays fixed. When you get home, have some fudge at Pickles Gap.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
06-29-2018, 03:29 PM
Gee Bill, I'm sorry to hear you guys are going through this again.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
06-29-2018, 04:10 PM
You shore seem to have more of your share of problems with your Creek. I hate to have one in the shop, it takes time away from camping
07-08-2018, 09:52 PM
Sorry to hear about the problems, hope Orvan can get it fixed. Is the piece that came off a piece that came from CC or is that one of the pieces that Orvan added along the bottom of the slideout to keep water from getting to the slideout floor? I've had the same issue with water collecting on the slide out covers. What I've done when moving campgrounds is to raise the rear jacks, then extend the front jacks to tilt the rig so the accumulated rain water runs harmlessly off the back (looks like Niagara sometimes) before pulling in the slides. I get it back close to level before pulling in the slides. Works really well and very little water runs down the sides of the slideouts.
07-09-2018, 04:31 PM
I'm at Blue Gate Motel. Unit is at Orvan's now. The floor is already replaced. He is working on the hydraulic issue (Though the dadgum levelup worked perfectly when I got there this morning........go figure!!!), and other things. On top of that he said "Oh, your front and back cap might be starting to fade a little, so we're replacing those". Among about 15 other piddling little things.
This guy is a Godsend. Just hope the hydraulic issues get finally fixed. I'll find out tomorrow about it all..........
Oh........his first thought on the water source was the window above where this issue, the little window in the slide.......might not have been sealed/caulked totally and might be the culprit. Still won't know till tomorrow.
And.......the broken piece in the picture is what came on it from the factory.
FROG AR-0019-242
07-09-2018, 07:49 PM
You, as you know. Have your RV in the best place to address your issues. Orvan and his crew are the best.
I had the same issue with my level up system. It would go through the process and indicate it was level but 2 legs would be off the ground. I would then level the unit in “manual mode”.
I fixed the issue by recalibrating level by performing the procedure for resetting level. I did this several months ago and have used auto level at least a dozen times since with no issues.
Good luck with your RV..
PS.. Blue Gate is a nice hotel but I found it to be the most uncomfortable hotel I’ve ever stayed. At least the room we stayed in. A small couch and 4 hardback wooden chairs. The staff is super nice and the free breakfast worked for us.
2016 Siverback 33IK
