Old 06-22-2015, 10:09 PM   #1
14 CC 38CK's Avatar
Name of water heater on a 38 ck
Ok I keep forgetting to look when I'm at the 5vr what kind of water heater is in the unit and size of drain plug , I think it's 1/2in.
14 CC 38CK is offline   Reply With Quote
Old 06-23-2015, 07:41 AM   #2
dieselguy's Avatar
Suburban ... 1 1/16" socket to remove drain plug.
dieselguy is offline   Reply With Quote
Old 06-23-2015, 09:49 AM   #3
14 CC 38CK's Avatar
Thanks dieselguy
Old 06-23-2015, 10:55 AM   #4
dieselguy's Avatar
I was thinking ... every once in a while they install Atwood water heaters. Do you remember if it had a plastic or metal drain plug? If it was plastic ... it is an Atwood and it'll be a 15/16" socket. The drain plug on Suburbans are actually a sacrificial rod (anode) and are metal. Atwood water heaters are aluminum, so they don't need the anode.
Old 06-23-2015, 11:06 AM   #5
wmtire's Avatar
You can also usually do a quick glance at the water heater door latch and tell the brand difference between an Atwood and Suburban also.
The stock Suburban latch is plastic and the Atwood is metal. Bclemens taught me that. Now if the latch has been replaced, then it's not so easy.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-23-2015, 11:43 AM   #6
14 CC 38CK's Avatar
Thanks guys , it's a Suburban , Metel drain plug and is 1 1/16
heater, water, water heater
