Old 07-07-2015, 05:07 PM   #1
HeyJude's Avatar
Need help with 2011 29re
I need to buy a new shower surround and I just got home (29RE is parked at campground), and I didn't know you had to measure for the apron (pan size).
Can anyone measure the pan from the top of the rim to the lowest point on the inside of the pan? I'm sure it isn't much more than 5" but I could be wrong. They come in two sizes 5" and 9", I'd hate to buy the wrong one. I have a guy coming out next week to install it, I was hoping to order it and have it by then.
HeyJude is offline   Reply With Quote
Old 07-07-2015, 07:17 PM   #2
arpipeliner's Avatar
This is mine in my 29RE.
Name:	ImageUploadedByForest River Forums1436314626.707341.jpg
arpipeliner is offline   Reply With Quote
Old 07-07-2015, 08:15 PM   #3
HeyJude's Avatar
Attachment 82306
You rock! Thank you so much!
Old 07-07-2015, 08:20 PM   #4
No problem. Had to replace mine so know that feeling.
Old 07-08-2015, 11:36 AM   #5
I also have a 29RE...Why did you have to replace the surround....cracked?...How???..J
Jim in Halifax is offline   Reply With Quote
Old 07-08-2015, 11:43 AM   #6
I noticed my new (2016) re has no caulking around the top of the shower when my last unit did. Are all the units like this?
offduty11 is offline   Reply With Quote
Old 07-08-2015, 12:49 PM   #7
Humm, we too had to replace the shower surround, 2010 Silverback RE29. We dropped the rig at the dealer fall 2013 to make repairs cause by a tire that de-laminated. Trailmate was the brand (China Bomb). Picked it up spring 14, checked the repairs and left for the ocean. Upon arriving at the ocean discovered a crack between the screw hole on the pinchy clip that holds the shower head and the top of the shower wall. Caulked it and taped it to get through last year, fixed it this year for almost $800.
Frankly, I thought the pinchy clip was Mickey Mouse solution. The white screw that held the clip rusted. Not a quality solution.
BeachLady is offline   Reply With Quote
Old 07-08-2015, 02:08 PM   #8
HeyJude's Avatar
It was already cracked when I bought it. Previous owner said it cracked during the winter cold, I believe him, seems like it happens quite often. I'm buying the surround myself and have a guy that is going to install it for $100 dollars. My husband could probably do it himself, but hurt his back this year and hasn't been able to do much.
Old 07-08-2015, 02:09 PM   #9
HeyJude's Avatar
Repair guy that is doing the install says the guys at the dealerships are paid very low wages and don't put the clips in correctly. Ours was screwed down too tight.
Old 07-08-2015, 04:32 PM   #10
Send a message via MSN to Tiggerdad
My 2013 Crusader is not caulked. Neither was my HR Savoy. Top of surround is above the shower head so I see no need.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
