Old 04-19-2014, 04:20 PM   #91
That did my whole top. Refrigator side took 4.
tarpumn is offline   Reply With Quote
Old 04-19-2014, 05:15 PM   #92
poofam's Avatar
rainy day project
Well gentlemen I covered up our backsplash today, Boss wanted more color. Tile saw didn't work real well had to score with blade the plastic grout line . Took about 4 hrs cost about $50. Need to get piece of trim for left side. Finally stopped raining but wet and a nice chill here on the river.
poofam is offline   Reply With Quote
Old 04-19-2014, 05:19 PM   #93
poofam's Avatar
Pics
ID:	50309   Click image for larger version
ID:	50310   Click image for larger version
Old 04-19-2014, 06:07 PM   #94
edt
Mine still likes the partial back splash so I will fill in missing pieces
edt is offline   Reply With Quote
Old 04-28-2014, 03:07 PM   #95
Microwave Issue
I was thinking about posting this in the Tech section but since we are Cottage folk, I would start here.
I opened up my CCK for the very first time this weekend since delivery last fall. When I got everything hooked up I noticed that there was no power to the microwave.
I checked the breakers located in the bedroom and they were on, toggled them to make sure that they weren't tripped. Still no power to the microwave. I then took an extension cord and plugged it into the outlet below it. (next to the oven) The microwave worked fine. Plug it back into the outlet in the cupboard where it belongs and no power. The outlet in the cupboard is not GFI, however I went through the kitchen area and push the resets on all the GFI outlets. Still no power. Everything else works fine in the unit.
Is there a breaker or a GFI that I am missing somewhere that anyone would know of other than what I have went through or am I looking at a outlet/electrical issue?
stever40 is offline   Reply With Quote
Old 04-28-2014, 03:46 PM   #96
heavynlori's Avatar
Our old Laredo fifth wheel had a kill switch that turned off power to microwave in order to use fireplace....
heavynlori is online now   Reply With Quote
Old 04-28-2014, 03:51 PM   #97
edt
Did this outlet ever work If it did knowing how sorry the elect outlets are made . There should be at least 2or 3 curits in the slide and M/w shouls be on a 20 amp
Old 04-28-2014, 04:26 PM   #98
Can run everything. FP and Microwave (when plugged in a different outlet) Fridge, TV, radio/dvd all running at the same time.
Thanks for the reply
Old 04-28-2014, 04:31 PM   #99
Not sure - I do not recall during walkthrough last year. Had wife look at that.
Not sure what you mean here. Everything on this slide is functional except for this outlet. The Microwave has a stand-alone breaker (located in the bedroom).
Looks like I need to get a tester to see if the outlet is bad or if there is no power going to the outlet.
Thanks for the reply.
Old 04-28-2014, 09:35 PM   #100
edt
Using a known good outlet ground check if you have voltage those wires just press into that outlet on the back. Wonder how many curits they have in slide
We are going back to trailer on the 10 of may will try and compare then
