Old 04-17-2014, 05:16 PM   #71
edt
ours has cabinet in bath also still had light switch in cabinet door took 15 minutes to move above thermostat
edt is offline   Reply With Quote
Old 04-17-2014, 06:14 PM   #72
You moved thermostat? ? Not light switch?
I added more stainless in kit. And am now puttig "glass" look tile around bath sink.
Wish I knew how to post pics.
tarpumn is offline   Reply With Quote
Old 04-17-2014, 07:02 PM   #73
edt
I moved the light switch to the wall above the thermostat a lot easier when you come in door to turn on lights
Old 04-17-2014, 08:14 PM   #74
I want to do this. Is it really a 15 minute job? Anything I should was for?
Old 04-17-2014, 09:51 PM   #75
edt
Take down display pannel 6 screws take picture of switch wires cut small whole above thermostat plenty of slack in wires careful lot of wires in area real easy to cut paneling with knike
Old 04-17-2014, 10:33 PM   #76
poofam's Avatar
Did you buy a new switch or use existing one ? How did you patch old switch hole ?
poofam is offline   Reply With Quote
Old 04-18-2014, 06:18 AM   #77
edt
Blank Home switch plate cover used same switch total cost $.59
Old 04-18-2014, 03:24 PM   #78
Posting a Pic
Tarpumn - To post a pic (if you are on a desktop PC) you will see a paper clip icon right next to the smiley face in the toolbar. Click on that, click browse (under the upload file from your PC) click on your pick and then click upload. Your pic will be loaded.
You might not be able to see it on the post you are submitting but you should on preview post. Otherwise just hit submit and it will show up
Hope this helps
stever40 is offline   Reply With Quote
Old 04-18-2014, 06:54 PM   #79
cottage pics
just finished adding more stainless in kit. and tile trim in bath.
also pic of bath cabinet.
Going to move the light switchs from cab. to wall at thermostat.
Down side.... ceiling fan in bedroom stoped? Fan light works.
Second outdoor speaker does not work.
Lots of fun.
ID:	50209   Click image for larger version
ID:	50210   Click image for larger version
Old 04-18-2014, 08:57 PM   #80
edt
Where did you get the stainless steel for kitchen did you replace what was there or did you find the same material
