Old 03-04-2015, 06:20 AM   #1
kinzoo's Avatar
New 5th wheel hitch..
Does anyone out there have a "Hijacker Automatic Sliding 18K 5th Wheel Hitch For Ford OEM Puck SYSTEM" and are you satisfied with it?????
kinzoo is offline   Reply With Quote
Old 03-04-2015, 07:56 AM   #2
bigdaddy1
bigdaddy1's Avatar
Do not know the answer but we have just ordered the "super glide" for our F350 standard bed truck so I have question to what is the hitch to have.
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2016 3850RL Cardinal
bigdaddy1 is offline   Reply With Quote
Old 03-04-2015, 09:31 AM   #3
Phat Phrog Stunt Crew
mackman1994's Avatar
I have a B &W that fits into the Ford ohm puck system. I absolutely love it and was cheaper than any other hitch. It is a 20K hitch.
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
mackman1994 is offline   Reply With Quote
Old 03-04-2015, 09:59 AM   #4
JohnF's Avatar
But thatís not a slider....correct?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 03-04-2015, 10:22 AM   #5
Fulltime family RVer
Correct. The only B&W Slider fits their Turnoverball gooseneck hitch. And it's a manual slider vs. automatic like the OP's Hijacker.
Old 03-04-2015, 11:25 AM   #6
kinzoo's Avatar
Duckogram,
"Interesting thread. The OP profile reads that he/she has a 2003 Chevy towing a 36CKTS.
Are you planning to put a Ford underbed hitch mount in your Chevy?"
"I" (me/he) have purchased Ford King Ranch, 6.7 Turbo, shortbed.
Just haven't changed my profile yet. I will change it when the truck is in the yard.
Old 03-04-2015, 12:01 PM   #7
brer_rabbit10's Avatar
I don't know what a puck is, but I have a SuperGlide #2900 in my short-bed F350. It works great and carries 18,000 pounds with a rated vertical load weight of 4,500 pounds.
brer_rabbit10 is offline   Reply With Quote
Old 03-04-2015, 12:02 PM   #8
Mark & Cindy Labbe
Reese makes adapters now for most OEM 5th wheel preps. You bolt the hitch to the adapter, which is permanently mounted to the hitch. The adapter interfaces to the OEM puck configuration. Go to etailers.com If you want to see what I am talking about. They show the comparable hitches with the adapter. Get the part number and check other sites for a cheaper price. They can be used with a slider. Your other option is a Reese sidewinder, which is what I am having installed on my 2015 Heritage Glen 356qbq.
marklabbe is offline   Reply With Quote
Old 03-04-2015, 12:58 PM   #9
Blog: RVroadtripper.com
hbillsmith's Avatar
Andersen Ultimate
Andersen Ultimate is an option that requires no slider. It's light and doesn't eat as much payload. Especially good if you already have an in-bed gooseball. Many threads on this board and on YouTube if interested.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is online now   Reply With Quote
Old 03-04-2015, 05:13 PM   #10
Hijacker
I installed an under bed mount Hijacker auto slide in my 2005 king Ranch about a week ago. Haven't pulled with it much but it has really worked great.
BTW I tried the B&W slider first and it didn't work well . That is why I went with the hijacker.
alayton is offline   Reply With Quote
5th wheel, hitch, wheel
