Old 08-23-2016, 02:01 PM   #1
New CC can't get tv sound to play thru Jensen jwm9a
We have a new CC 38el and with Samsung tv. We can't get the sound from the tv to play through the Jensen jwm9a. Any help would be appreciated. Thanks.
Brady is offline   Reply With Quote
Old 08-23-2016, 04:33 PM   #2
ilmor's Avatar
We have jwm6a, not 9a, but if similar you need to keep pressing Mode Display button until you get HDMI ARC.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-24-2016, 08:36 AM   #3
Thanks for your help. I checked and still no sound from TV. I'm starting to think maybe they didn't wire from tv. I'll ask when I take RV back in for fine tuning in October.
Old 08-25-2016, 07:04 PM   #4
You would have to have an output from your TV to the receiver to play sound. The receiver is probably setup from the factory to only play sound when using the DVD player.
ralderman is offline   Reply With Quote
Old 08-25-2016, 07:27 PM   #5
JohnF's Avatar
Press mode until you get HDMI Arc...then press ENTER. Give it a few seconds and make sure the sound level is up.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is online now   Reply With Quote
Old 08-26-2016, 01:38 PM   #6
Try tracing the the audio input to the Jensen back to the TV. I found that the audio cable was hooked to the wrong jack on my TV.
Okie
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
USMC Okie is offline   Reply With Quote
Old 08-26-2016, 03:45 PM   #7
U definitely have too push enter after every mode change or it will go back to last setting. As JohnF said, HDMI arc on display then push enter.
cody1884 is offline   Reply With Quote
Old 08-26-2016, 06:36 PM   #8
Thanks for all of the suggestions. I have tried the HDMI aux and enter several times. I am begining to think the tv is not connected to the Jensen. I have had the tv off the wall once for a different reason and wish I had looked then. I don't look forward to taking it down again. Thanks again to everyone for the replies.
Old 08-26-2016, 07:50 PM   #9
My Creek I had for over a year and I couldn't get the Jensen tv to play through the speakers, then I had a place that installs sound equipment install my Trav'ler on my Creek and he had the tv playing through the speakers, I had tried for over a year and he had everything working in just a few minutes. I'm going to buy a sound bar from them and let them install it. I plan to get rid of everything Jensen.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 08-26-2016, 08:32 PM   #10
wls
where is this mode button? thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
wls is offline   Reply With Quote
jensen
