Old 04-17-2013, 05:10 AM   #1
BoatDude's Avatar
New CC question
Our new CC will be plugged into a 30 amp supply box. I'm looking into purchasing a surge protector. We bought the 50 to 30 reducer plug, from coach to box. My question is which surge protector do I need. A 50 amp or 30 amp? Any suggestion would be appreciated.
BoatDude is offline   Reply With Quote
Old 04-17-2013, 06:03 AM   #2
If your coach has 50 amp service, I would go with a 50 amp surge protector. For your home setup you can go reducer to surge protector to coach. When you're out using 50 amp service somewhere you'll still be able to use the 50 amp surge protector with the 50 amp plug.
I personally however would go with a 50 amp hardwired power protection system - it provides for much more protection than just a surge protector. We installed the EMS-HW50C Progressive Industries EMSHW50C Surge Protector : Amazon.com : Automotive
2007 Chevrolet Silverado 2500HD Duramax Diesel
2012 Cedar Creek 30RL
Full Timers Since October 2012
RenoRock is offline   Reply With Quote
Old 04-17-2013, 06:28 AM   #3
TURBS's Avatar
X2
Ems system has a lifetime warranty!
Lets you see incoming volts
Current amp usage.
Hertz
Fault codes
Turbs
Old 04-17-2013, 06:55 AM   #4
BoatDude's Avatar
Any suggestions on installation of the hardwired type? Can I do this myself? If you have a pics on your installation please send. Ours is a 36ckst. We have the inverter model.
Old 04-17-2013, 06:56 AM   #5
TURBS's Avatar
Installed mine in less than 30 minutes.
Old 04-17-2013, 06:58 AM   #6
TURBS's Avatar
Pulled converter/distribution center
Converter has 6 screws and simply pulls out.
Cut incoming line and wired in quick disconnects in case removal of surge was needed you can plug converter back in while surge is out.
Thanks "qccowbboy"
Screw surge to floor and replace distribution center.
Old 04-17-2013, 06:59 AM   #7
TURBS's Avatar
Mounted display monitor on face of distribution center.
Simple and easy.
Only incoming wire needs cut and attach one end to in side of surge and other to the out.
Old 04-18-2013, 10:51 PM   #8
BoatDude's Avatar
Thanks, I agree, I ordered it today.
