Old 04-17-2014, 11:51 PM   #11
Plain Old Member
Overall a decent RV, but please do triple check everything from water connections to under the slides. You can follow a few of my threads and see the problems we've been having, the most recent being a wet slide floor due to a poorly sealed t-molding, cracked front cap (round 2 of this) and a cracked outdoor kitchen door. Check the Darco fabric under your slides for tearing or wear. They can install plastic glides to prevent this. We've had a LONG list of problems with ours, most of which I fixed myself. On the sealant on seams, they left a lot that I would usually seal, so 4 tubes of proflex later, it's as good as can be, and I still had a leak. Overall, it's as good as any to us with the modern day way of building them. Fast, cheap and a lot to be desired on the QC level. I suppose we got one of those 1 out of 10 that has issues.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 04-21-2014, 09:09 PM   #12
Leaving Atlanta early tomorrow heading to south Florida and pick up our 2015 Silverback 33rl. Have the heavy duty PDI sheets and ready to test and double test everything. Dealer said to expect his team to spend 3 hours going through the unit. This is our first rear living unit. We added bedroom ac, Whirlpool micro convection oven, TrailAir hitch . Have new Tire Minder TM66, so hopefully no tire surprises!!
More when we have Silverback experience!!
SilverbackMel is offline   Reply With Quote
35qb4
