Old 08-21-2016, 03:37 PM   #1
New Cedar Creek Owner.
Hello all,
I am a new Cedar Creek owner picking up a 2017 38CK from the dealer this Friday. I have a question about the 6 point level up system. With this system what do you recommend for under the pads between the jacks and the ground or if anything. We will be living in it full time.
Thank you in advance.
Phipp is offline   Reply With Quote
Old 08-21-2016, 03:44 PM   #2
clr
I use a 2x12 with a 5/16 inch I think plywood top with the grain running in the opposite direction glued and screwed together and then painted white. This set up works well for me.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-21-2016, 07:03 PM   #3
Welcome from Wisconsin and congrats in your new CC!
Old 08-21-2016, 11:35 PM   #4
I wouLd recommend Snap Pads. I installed them on my 5th wheel and really like them. Make sure you get the upgraded ones that have the slots for water drainage, same price....
RV SnapPad Products
Old 08-22-2016, 08:18 AM   #5
Jim34RL's Avatar
RV SnapPad Products
I reviewed them and you only get about 1-1/8 inches of pad under the hydraulic rams foot. Which I feel is totally in adequate for the support of the rams to prevent motion in the camper.
I have two 4X4X10" long cedar blocks under each front ram and I place between three and four Link pads under each rear ram (4). This way the rams are extended the shortest distance on level ground and you get less movement (or bending) of the rams. I have found that when the hydraulic rams are extended to far the trailer will wiggle and bounce when you walk in the trailer. By keeping the ram short the motion is non-existence when you walk.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 08-22-2016, 09:14 AM   #6
I don't use anything and I don't notice a problem. Try it first with nothing, if your not satisfied, Try using the pads.
mbienve is offline   Reply With Quote
Old 08-22-2016, 09:29 AM   #7
I sometimes have a problem of the wheels coming off the ground, I like for the wheels to stay on ground
spock123 is offline   Reply With Quote
Old 08-22-2016, 09:32 AM   #8
JohnF's Avatar
Ditto
My first mod would be awning hold down polls from Turbs.
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 08-22-2016, 10:23 AM   #9
Leonandpandora's Avatar
I have a cardinal but we use 3 2x12 blocks with the grain alalternating screwed together. Then we bought a stall pad from tractor supply and cut it to the same size as the block tops. Keeps the rams from extending . seems pretty solid when the dogs are jumping around inside.
Stall pad is made from recycled tires and helps take out some of the pop and crack that happens with temperature changes.
2016 F350 6.7 Drw 4.30 gears
2016 Cardinal 3825 FL
2011 Big Country 3500RL...Sold
DW, 2 Spoiled Beagles IZZY and Pup Pup,
And Hillbilly Bob an American Bobtail Rescue Cat.
Seeing America one jobsite at a time..
Leonandpandora is offline   Reply With Quote
Old 08-22-2016, 10:24 AM   #10
Should read extending too much.
Old 08-22-2016, 12:39 PM   #11
mbbutler's Avatar
4x6. Light once they dry out, and can stack them to keep leg extension to a minimum.
mbbutler is offline   Reply With Quote
Old 08-22-2016, 02:03 PM   #12
Hoss pads
I use Hoss pads under mine. Bought them on Amazon. They are made from recycled rubber. I bought these before Snap pads were available. If I had to do it again I would go with the Snap pads.
2015 GMC Denali 3500 4X4 Duramax
2019 Cedar Creek 36CK2 (sold 4/21)
grumpyoldman is offline   Reply With Quote
Old 08-22-2016, 05:56 PM   #13
Jesse's Avatar
Feet
Lynx levelers with lynx pads on top. Easy to use, easy to clean, cheap to replace if lost.
Jesse
2016 F450
2017 Cedar Creek 38EL Champagne
Only here once - do it baby!
Jesse is offline   Reply With Quote
Old 08-22-2016, 06:40 PM   #14
X2 on the Lynx pads, I had them on a travel trailer, light
Old 08-25-2016, 09:08 AM   #15
Thank you all for all your comments, lots of good ideas.
cedar creek
