Old 02-02-2013, 02:53 PM   #1
New Sewer Hose Storage
Didn't want a hose hanging around outside the rig, the built-in hose holder is too small for the connectors (keeping the clothes line in that).. So installed a 5" fence post inside the storage area. Hangs from the from using a custom built clamp. Need to make some covers for each end and then good to go.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 02-02-2013, 03:40 PM   #2
Twisty's Avatar
Nice!!
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 02-02-2013, 03:56 PM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
Looks nice...how do you keep water from dripping out of holder?
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-02-2013, 03:59 PM   #4
Going to make covers for both ends. Also keep caps on the hose ends.
Walter & Donna
Old 02-02-2013, 04:40 PM   #5
Owner/Operator
RodeoGeorge's Avatar
I use basically the same thing, only mounted under the RV on the frame just forward of the wheels where it is close to the dump outlet.
Instead of the square fence, I use the 4" white leech field thin wall ABS pipe and position the holes on the bottom so that any residual water can drain out. There are also plastic floor grates (Lowes or Home Depot) that fit nicely into the pipe as a cap. By drilling a hole on each side I can slide a piece of coat hanger through the pipe&cap to hold the cap in place while traveling.
The other advantage to this type of holder is that you can make it the width of the RV, and thus accommodate a 20' Triple Wrap hose.
To mount to the frame, you can go through one of the drain holes on the bottom of the pipe and screw it (with a washer) into the frame.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-02-2013, 04:50 PM   #6
racedaymechanic's Avatar
I just use a Plastic tote witha secure lid and keep it in the back of the truck, I wouldnt mount that inside the trailer, Yuck
2009 Sabre Palomino "Sissy"
1998 Chevrolet K3500 6.5 Diesel "Brutus"
racedaymechanic is offline   Reply With Quote
Old 02-02-2013, 05:29 PM   #7
rattleNsmoke's Avatar
I'm gonna fabricate one from Septic pipe as well. I'm thinking of using U shaped band clamps screwed to the frame to hold 'er in place.
rattleNsmoke is offline   Reply With Quote
Old 02-03-2013, 07:38 AM   #8
Yep nice idea and looks great. But I'm with a couple of others that 'stuff' stays outside not in my storage area.
Jimtc is offline   Reply With Quote
Old 02-03-2013, 08:21 AM   #9
67redbowtie's Avatar
X2
67redbowtie is offline   Reply With Quote
Old 02-03-2013, 04:27 PM   #10
Version 2
Well the boss informed me that she would be putting stuff in "my" tool storage spot and so the hose can't stay... so now it is a flag pole holder... Hose is now located underbelly forward of the spare. Even thought it is a balmy 22 deg out... figured I should just get it done...
Walter & Donna
Old 02-03-2013, 05:15 PM   #11
Now that's the way to do it. Nice Job. It keeps the sloppy stuff outdoors where it belongs.
Old 02-04-2013, 06:39 AM   #12
showtime0022's Avatar
You cant argue with the boss!.... Lol
showtime0022 is offline   Reply With Quote
Old 02-04-2013, 06:50 AM   #13
DAISY BOYKIN's Avatar
Did you drill---------------
I sure hope you drilled some drain (3/8")holes in the bottom of the storage tube. Each time I store my hose, it still is wet inside and outside if I rinsed it off. From time to time, I even have to rinse the inside of my storage tube.
Nice job on installation!
OOPS, I just read your post #5, You did drill some holes.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 02-04-2013, 08:33 AM   #14
I have two of the 5 inch PVC's mounted under our unit. One contains the sewer gear and the other a coiled hose and our long handled hot-dog sticks.
Yes I did drill several holes in the bottom of each to drain.
JJnLilly is offline   Reply With Quote
Old 02-04-2013, 08:41 AM   #15
dezeldad's Avatar
same idea here except I used the round PVC.
dezeldad is offline   Reply With Quote
