Old 12-19-2014, 02:18 PM   #1
DLBLISSII's Avatar
New Silverback 31RK Owner with a Battery Question
We purchased a new 2015 Silverback 31RK and have a question... We have a single 12 volt battery, is that normal or should it have either (2) - 12 volt batteries or (4) - 6 volt batteries? Thanks for your help.
DLBLISSII is offline   Reply With Quote
Old 12-19-2014, 02:57 PM   #2
Oakman's Avatar
Just one (1) 12 volt battery is normal.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 12-19-2014, 03:10 PM   #3
Mine came with one but I always have two on board. We dry camp most of the time so we need the extra amps.
Pipeman is offline   Reply With Quote
Old 12-21-2014, 05:50 PM   #4
Standard is one 12-volt battery, unless you have the Residential Fridge with inverter. Then you need to have (and should have) 4 6-Volt batteries.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 12-22-2014, 06:48 AM   #5
DLBLISSII's Avatar
Thanks! Yes we have a Residential Fridge and inverter.
Old 12-23-2014, 04:35 PM   #6
I am in the RGV in Texas and having frig trouble any dealers near here I can get a hold of. Camper is still under warranty. Have had this trouble since it was new, no luck with dealer at home fixing it. any help would be appreciated
Silverback Iowan is offline   Reply With Quote
Old 12-25-2014, 11:30 PM   #7
I asked for 6v batteries and they installed 2 of them.
stormy2000 is offline   Reply With Quote
Old 04-29-2015, 02:00 PM   #8
DLBLISSII's Avatar
Problem Solved
Well just to close out my post... after replacing the inverter (original one was bad) and installing two 12 volt batteries, we are now up and running. Thanks for the replies.
Dennis Bliss
2014 Ford F250 Platinum
(6.7L Powerstroke (SRW))
Old 04-29-2015, 02:12 PM   #9
I think 4 6 volt batteries are better than 2 12 volt batteries
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 04-30-2015, 10:13 AM   #10
One Battery
I have the same coach and one is standard. I will be adding an additional battery simply because we dry camp several times a year. I also have a portable generator for backup.
AZMac is offline   Reply With Quote
battery
