03-13-2018, 03:48 PM
New to us 34RL
Just Upgraded to a new to us 2016 Cedar Creel 34RL. WHO HOO! The previous owners were not real helpful explaining everything to us so I am coming to the experts here. On the 2 tv's in Living and Bedroom do they have pull out mounts to get to the backs to check how the cables are run? I don't want to pull too hard on the tv and break it but it sure would be odd not to be able to pull it out and turn the angle of it .
2016 Cedar Creek 34RL
2014 Ram 2500 4x4
03-13-2018, 04:08 PM
member
Don't know about the tv but I was interested in purchasing a CC 34Lr but thought it would be too much for my 250. So I am leaning towards the silverback 33ik have you towed with it yet? And if so how did it handle? Not so much on the power as I see you have a diesel my concern was about the payload very interested how your truck handled it and did you add any suspension upgrades thanks
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
03-13-2018, 04:23 PM
I haven't towed it yet but the original owner brought it to the house with his chevy 2500 and he said he never had any issues and it was pretty level. I plan on getting air bags though
2014 Ram 2500 4x4
03-13-2018, 05:10 PM
Not sure about your tv mounts but our Cedar Creek 36ck2 has a pivoting mount in the main living and liftoff mount in the bedroom. For the bedroom, I just grab the tv at the bottom and lift up and it comes off the mount so I can get to the wires.
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
03-13-2018, 06:25 PM
My guess the PO was ignorant. That fiver can be very pin heavy when loaded for travel. 2500s are simply not enough truck for most Creeks. Before you spend one dime on your truck, load the trailer up and get it weighed hitched to your truck. But be prepared for the consequences.
At over 16,000 GVWR that is really in dually territory.
03-13-2018, 09:36 PM
What I would do is first load for camping and see how the Creek towed before I brought another truck. With 4200 lbs CC I doubt if you will ever be over 16,000lbs. I would think the most y’all will ever carry is 1500 lbs.
03-13-2018, 09:40 PM
Oh yes enjoy your new to you camper. You have any problems this is the place to come first
03-14-2018, 08:05 AM
One thing is certain on all RV Forums. You can be pulling a popup with a Kenworth and someone will say you don’t have enough truck!
03-14-2018, 08:22 AM
Censored Member
You got that right!
03-14-2018, 08:41 AM
That has to be one of the dumbest comments so far.
The guy has bought himself a 16,500 pound GVWR fiver. Whether he does or does not get close to the fivers GVWR, the potiental is there. If he is crazy enough to think he can safely pull it with anything less than a one ton dually, he is either as crazy as the guy that he bought it from or is plane uninformed. Either way the OP needs to have sufficient tow vehicle to safwly handle the full load.
Yea, I know some people attempt to rebuild a motor using nothing but a screw driver and a pair of pliers. While othera will do the job using the correct tool. He really needs to understand and have the correct tool or dont start the job!
03-14-2018, 10:50 AM
That is so true!!
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
03-14-2018, 12:43 PM
Hi, Welcome to your 34RL Cedar Creek.
I too have a 2016, 34RL Cedar Creek being pulled with a 2008, 2500 Dodge Mega Cab with the 6.7L Cummins and the 68RFE auto. I am not a member of the Weight police and I do not enforce their agenda. The only change I made was to the rims and tires changing to a LT285/70/17 126S Nitto Dura Grappler tires..
Now to your TV question, The TV's are supported with two brackets that you need to pull down a little and out to separate them. I had to do this to replace my rear TV bracket since we wanted a swing out TV bracket. The factory brackets do not swing but are stationary.
Good Luck
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
03-14-2018, 01:09 PM
Thanks Jim, for the TV answer
That is all I really wanted to know. Things go off subject real quick here
and for all the weight issues brought up I willl check my weights before I travel and appreciate your input
Thanks again.
2014 Ram 2500 4x4
03-14-2018, 05:33 PM
You know if I s the biggest word in the dictionary
