Old 01-13-2013, 10:42 AM   #11
Thanks for the info Pitcrew. The possibility of the sway is one of my may concern's with a SRW. Hearing from someone who has pulled this size with a SRW is helpful. Appreciate the info from life2short..too. I'll have to think about that and maybe go smaller or possibly put dually kit on my truck for more stability.
IndyBob is offline   Reply With Quote
Old 01-13-2013, 11:32 AM   #12
mike06081969's Avatar
I pull a 2011 Blue Ridge 40' 5er with a dry hitch weight of 1,930 lbs, an unloaded vehicle weight of 13,159, and GVWR of 16,080. My tow vehicle is a 2008 Ford F-250 4x4 with the 6.4 powerstroke. I had a set of Firestone Ride-Rite air bags installed with in-cab controls. I've pulled it on several long trips and never had any trouble at all with sway. As long as I keep 50 to 70 psi in the air bags, it drives great. I try to hold the speed to 65, but sometimes have let it get as high as 75 going downhill and still didn't feel unstable. I keep a good set of Michelin load range E tires on my truck and keep them inflated to 80 psi. I don't think you would have a problem pulling with your SRW IF you have airbags. My truck didn't steer well at all pulling this beast before I added the bags.
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
Old 01-13-2013, 02:40 PM   #13
Thanks for the info Mike. After thinking this over more, I may just go with this size 5er and see how it does tow with the airbags and if needed, then add the dually kit. Not ready to upgrade to a new truck at this point and like what I have, which only has about 55K miles on it. I really appreciate the info from all and use it in my decission.
Old 01-30-2013, 12:47 PM   #14
Here is what I pull...
Indybob,
I have a 2006 GMC 2500 with a duramax diesel and allison transmission...pull a cedar creek 362bts with no problem. The truck rides level and has plenty of power. I did not need to add airbags. I am selling the camper now, you can go under the classifieds and see pictures of both the 5th whell and the truck hooked up.
lyonsden is offline   Reply With Quote
Old 01-30-2013, 01:19 PM   #15
Thanks for the info Lyonsden.
