Old 08-22-2013, 07:56 PM   #41
dcheatwood's Avatar
You know, if N is so good at not leaking and staying at same pressure, then why do we have to check our N- filled tires every trip and add air all the time? Just saying. My last 2 5ers had nitro at first and had to be topped off all the time.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 09-11-2013, 11:18 PM   #42
OL Creeker's Avatar
I have a pancake compressor in the front basement area, which I plug into the inverter when needed - which is prior to EVERY time I hook up! Believe it or not. No, there's nothing wrong with the tires. I increase PSI in the TV tires according to the load, reduce it when we arrive. The load is pretty constant. DW can only get so much in this rig!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 09-11-2013, 11:24 PM   #43
OL Creeker's Avatar
Your tires
I don't want to sound like a SA. But to not have checked your TP in so long, to me is ridiculous and unsafe.
Duramax/Allison
Old 09-12-2013, 12:00 PM   #44
Senior member
geodavis's Avatar
just replaced all of mine blistered and bubbled. Had less than two thousand miles on them. Put goodyear air filled on.
2012 Salem 27rls TT
2006 Dodge Ram Big horn 5.7 v 8
2012 camped 32 days
2013 so far 48 days
geodavis is offline   Reply With Quote
Old 09-17-2013, 08:14 PM   #45
Commercial Member
Sounds like you have an air leak(s) if you need to add air each travel day.
N2 does leak out just slower than O2
Here is my post on N2. It may answer your questions.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 09-17-2013, 08:54 PM   #46
And how do you determine whether to increase PSI according to load if the load is pretty constant? Why do you reduce it when you arrive???? Do you weight every time you move the trailer?
