Old 04-21-2016, 08:47 AM   #31
elrand's Avatar
if you change those valves and have water pouring out id check your water heater to see if there is another valve there that is open to drain the unit.
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
Old 04-21-2016, 09:16 AM   #32
AquaMan's Avatar
X2!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-21-2016, 09:21 AM   #33
AquaMan's Avatar
Check to make sure your pressure relief valve is closed!
Old 04-21-2016, 10:49 AM   #34
wls
Your in bypass for your hot water. the three valves i circled should be changed. you will have water come from your taps due to the middle valve being open. the others take water to and from your hot water heater
I'm going to change these 3, but I think I've done that and it pours out the bottom. When looking, and I will again, I do not see any valve on the water heater itself. Maybe I have to take a panel off, but in my instuctions and the one posted on here does not say anything about a shut-off, or drain valve. I'll go thru it again tonight when I get home.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 04-21-2016, 11:04 AM   #35
wls
I looked at post 13, opened up the manual and noticed a panel that can be removed, and a system drain knob is seen in figure #10. Maybe the factory or dealer turned it during winterizing. If I turn the shut off valves to the way we think they should be tonight, and it still flows out the bottom, I'll pull that panel and turn the knob.
Old 04-21-2016, 05:21 PM   #36
Rest and Relax's Avatar
Did you read the draining and storage portion of the manual in post 13? It states unit must be drained and refilled in spring and air removed prior to lighting.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 04-21-2016, 05:58 PM   #37
Director, FROG
F.R.O.G.'s Avatar
I hope that you've not turned on the water heater without being certain that it's full of water. Make sure that the air is purged and the tank full before turning on the heater, or you can burn up the heating element in a heartbeat.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 04-21-2016, 06:10 PM   #38
bubbles's Avatar
You really need to check posts from the beginning. The water heater is an ON DEMAND system.
Old 04-21-2016, 06:55 PM   #39
wls
Got hot water, turned the valves the way everyone thought they should be, still had water coming out of the drain. I took the panel off the rear of the water heater, and there's a 1/4 turn valve to drain the water out of the heater, for winterizing, turned it 1/4 turn close, works great, actually could be a little hotter, but at least it hot. I believe there a adjustment to make it hotter. I want to thank everyone for their help.
Old 04-21-2016, 06:58 PM   #40
TURBS's Avatar
No hot water
I guess where everyone is going wrong is they see suburban on demand and all they see is suburban, I didn't even know they made an on demand.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
hot water, water
