Old 04-20-2016, 07:47 PM   #1
wls
No hot water
I hooked the water up to the rig, got all the rv antifreeze out, thru the cold and hot lines. So I flipped the switch on (suburban on-demand) and no hot water, gas turned on, have gas back to the cook stove so I figured it made it to the water heater. When I turned the switch to the on position, very faint light came on for a millisecond. Let the water run for quite some time, and numerous times. No sound of trying to light, no flashing light, talking about the little red light by the on/off switch. Oh I have a good flow of water coming out of the faucets. Any ideas? Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 04-20-2016, 07:51 PM   #2
You still have the valves in bypass.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-20-2016, 08:10 PM   #3
wls
Here is how I got them.
Old 04-20-2016, 08:15 PM   #4
wls
sorry for the side view, but if I turn the one on the blue and red in the center of pic, inline, (they go to the water heater) it will dump the water thru a hose that dumps to the ground. I have to get the pics off my phone, but theres 2 lines that hang below the heater.
Old 04-20-2016, 08:18 PM   #5
wls
Here is the 2 hoses hanging, and where they come out of the heater
ID:	105581   Click image for larger version
Old 04-20-2016, 09:01 PM   #6
TURBS's Avatar
No hot water
How do you know the tank is full?
Did you check the reset buttons on the water heater.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-20-2016, 09:23 PM   #7
bubbles's Avatar
Those 3 valves appear incorrect for non by-pass. There is a pictorial at the bottom of your photo showing manifold bypass valve positions. Have you positioned the valves to the correct position for non by-pass?
Old 04-20-2016, 09:36 PM   #8
TURBS's Avatar
Originally Posted by bubbles View Post
Those 3 valves are incorrect for non-winterization. They are in by-pass.
And this is why I say to open pressure relief valve in order to fill water heater tank, turning on a hot water tap tells you nothing, as you'll still get water out of it if bypass valves are incorrect or forgotten about.
Old 04-20-2016, 09:41 PM   #9
WFD
If you are in bypass mode then you never filled the hot water tank. Now if you tried lighting it, you may have burned out the heater element.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-20-2016, 09:57 PM   #10
bubbles's Avatar
The OP said he had an ON DEMAND water heater but it appears he may not have one. I recently posted on another one of this OP's questions and he indicated at that time also he had an on demand system.
hot water, water
