Old 05-03-2016, 08:06 PM   #11
TURBS's Avatar
Originally Posted by Jim in Halifax View Post
On my 29RE CC 5er they show 2 fans on fridge schematic.....They must be between lower and higher vents......I cannot hear them...I am thinking that they may not be there without taking the unit out from inside......any ideas???? J
Jim, I was able to take the top vent off and look down to see a single fan in mine.
Old 05-04-2016, 12:49 PM   #12
If your fridge is in your slide they are likely there. It has to get pretty warm before they turn on. Maybe use camera or mirror to view them between vents
Doug Currie is offline   Reply With Quote
Old 05-04-2016, 01:32 PM   #13
TURBS's Avatar
I turn my fans on at 102 degrees
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Old 05-04-2016, 01:42 PM   #14
2008 2500hd Duramax
2015 Columbus 320RS
????? Have you installed fans that are manually switched "on" when outside temps reach 102*F????????
Jim in Halifax is offline   Reply With Quote
Old 05-04-2016, 01:49 PM   #15
TURBS's Avatar
No my fan controller automatically turns them on when the fridge cabinet area reaches 102 then shut off when cooled down to 95
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-04-2016, 01:50 PM   #16
TURBS's Avatar
Noisy Dometic fridge fan
Temp probes are In between cooling fins.
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-19-2016, 09:21 PM   #17
patchman's Avatar
Turbs, with your temp controller parameters set at 102 and 95 do you find your fan(s) cycling on and off a lot? I'm assuming that with this narrow of a temp variation you are achieving a more constant temperature in your fridge.
Dianne & Dave
2013 Columbus 320
2014 Ram 3500 HD srw
patchman is offline   Reply With Quote
Old 05-19-2016, 09:56 PM   #18
TURBS's Avatar
They do not turn on and off much they mostly run but keep a constant temp outside and in!
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
Old 06-20-2016, 04:57 PM   #19
noisy Frig fan
Turbs Thank you so much for all the info. 1 more question did you replace the wooden baffle. I am not even sure why its there.
sstaubs is offline   Reply With Quote
Old 06-20-2016, 04:58 PM   #20
TURBS's Avatar
The one the upper fan is in?
Sent from my SCH-R530U using Tapatalk
dometic, fan, fridge
