Old 05-01-2016, 05:47 PM   #1
Noisy Dometic fridge fan
It was our second trip out with the new trailer. The fridge just started making a loud buzzing sound. I believe it's the cooling fan. Anyone else have this happen and is the fan easy to replace
Doug Currie is offline   Reply With Quote
Old 05-02-2016, 11:42 AM   #2
Head Rambler
What model fridge do you have?
Gotta go campin!
Old 05-02-2016, 01:05 PM   #3
TURBS's Avatar
I disconnected the loud stock fan and put in a bigger quieter one.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Old 05-02-2016, 01:15 PM   #4
Don't Camp Enough
DSMURPHY's Avatar
Replaced my fans with 120mm 1200rpm fans from the "CoolerGuys"
'2016 Rockwood 8288WSA
'2010 Tundra
DSMURPHY is offline   Reply With Quote
Old 05-02-2016, 01:22 PM   #5
Dm2862lbfx
Old 05-02-2016, 01:29 PM   #6
I only have 1 fan just below top vent. It looks very dirty. New trailer to. Think I will replace with new one maybe 2. TURBS it looks like yours was replaced with 115V fan.
Old 05-02-2016, 01:32 PM   #7
TURBS's Avatar
Doug, I replaced it with two actually.
1 120v and 1 12v
The top is 120v but I also added a temp controller as you can see above the fridge.
I also have the same size fan in the lower compartment that is 12v and also runs on a fan controller.
Both 120mm
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-02-2016, 01:59 PM   #8
Ok that makes sense. Did you remove fridge or work through the 2 outside vents.
Old 05-02-2016, 02:12 PM   #9
TURBS's Avatar
Worked through outside vents
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-03-2016, 07:56 PM   #10
On my 29RE CC 5er they show 2 fans on fridge schematic.....They must be between lower and higher vents......I cannot hear them...I am thinking that they may not be there without taking the unit out from inside......any ideas???? J
Jim in Halifax is offline   Reply With Quote
dometic, fan, fridge
