Old 05-28-2013, 04:54 PM   #1
mike2wheels's Avatar
Observations of first trip
We've had this unit for a month and towed it a total of about 75 miles. This trip was just up the road a bit to see how everything worked. First off, stupidity strikes. I knew this trailer is 39' long, but I bought a 25' water hose. So we're using the fresh water tank and pump this trip, which works fine except the flow rate is low. Next trip, a 50' hose.
My overall impression is disappointment in the build quality. Interior trim not tacked down or loosening; door tracks not screwed down; outside storage door not mounted correctly. Doesn't anyone at Cedar Creek know how to use a vacuum cleaner? Every cabinet contains wood shavings.
We have found that even 2 A/C units have a tough time coping with southern Arizona heat. We have a 15K A/C in the kitchen and a 13.5K A/C in the rear bedroom. And it's not even hot yet; only in the upper 90s this week.
Truck does fine towing this trailer. Weighed yesterday we gross at 20240 with half a tank of fuel and 3/4 tank fresh water and two adults. The truck weighs 8000 with people and full fuel. I'm still adjusting the built-in brake controller, but it's close. We get a clank from the hitch on braking and aggressive take off, but otherwise the trailer seems to float along behind us. Truck sits level with 30 psi in air bags, but the trailer is just a bit nose high.
A pleasant surprise was the effectiveness of the sculpted nose on the Silverback. The truck is a short bed SRW, but I tried backing into a 90 degree jackknife and had plenty of room. I think the corner of the trailer will hit the side of the cab before it hits the rear window. But with the pin box out over the bed rail, I'll have to watch that.
Overall, we're happy with it and making a list of modifications. Next stop is back to the dealer for some minor fixes.
2005 Honda Gold Wing
2010 Dodge 3500 SRW
2013 Cedar Creek Silverback 35FL
mike2wheels is offline   Reply With Quote
Old 05-28-2013, 06:27 PM   #2
Oakman's Avatar
It sounds like your dealer didn't do a proper prep on your Silverback, it's part of their job. New trailers will shake out wood dust and shavings on the way to your dealer from the factory.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-28-2013, 06:57 PM   #3
Former Full Timer
Duckogram's Avatar
From experience... Think about 3 x 25' hoses. One for a spare when (not if) one breaks.
The sawdust appears to be a trademark CC thing. The dealer should have vacuumed it out of the cabinets and storage compartments but you will find more in the crevices behind things and in the belly when you have to adjust things.
The A/C efficiency can be improved by making reflective panels and placing them behind the shades on the sunny side. Slide out toppers and awnings help as well.
Hope this helps.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 05-28-2013, 07:27 PM   #4
rattleNsmoke's Avatar
Typically you have MORE water pressure from your inboard pump than the city water connection. If your disappointed with the flow at the faucet heads, wait until you hook up to the campground city water hookup. It will be far worse when using a regulator. Your choice is to either remove and drill larger holes in the rubber washer 'limiter' in the faucet heads or remove them completely. Second, I'm surprised how light your diesel tv is....only 8000lbs with passengers and full fuel? My F350 pushes 9200lbs for a short bed SRW with fuel and passengers. So far it seems that you've had issues with fit and finish on your trailer. Well, welcome to RV World. I swear the employees late for their AA meetings when they slap these units together. The underside cabinetry and storage belly of The Beast looked like a parakeet cage with all that sawdust. Mine is a 2010 10th Anniversary edition(whatever that means) and they applied a raised fancy 10th Anniversary decal to the outer wall right under the grab rail for the world to see and guess what?? They stuck it on UPSIDE DOWN!! I'm apprehensive in peeling it off 'cause I'll prolly remove the Creekside lower paint in the process. Repair what you can, modify the rest, and above all chill out and enjoy the summer.
rattleNsmoke is offline   Reply With Quote
Old 05-28-2013, 07:36 PM   #5
kc8lvy's Avatar
The first thing I ordered for mine was a new 25ft hose and a a 50ft hose. I don't know if you got a 30ft - 50 amp extension cord and a 50 amp to 30 amp adapter cord yet. These come in real handy I have had my camper out 4 times this year and needed the adapter 3 times and the extension cord 3 times also.
Sawdust keeps seeping out of the crevices on mine also maybe by the end of the season we will get it all swept up.
How do you like the front living Silverback? We seen some other brands that were front living but not in a Silverback. I went with the Silverback 33rl and really like it. We are planning on moving next year and living in it a while until we find out where we might want to settle down.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 05-28-2013, 07:39 PM   #6
Plain Old Member
Sawdust is a trademark of the whole RV industry. Be glad that's all you found. I got cut outs from roof and floor, wires, screws and on and on. Clean up and move on, it's normal. As long as you have no structural issues or water leaks, I'd say you've done great. A few cosmetic issues are easy fixes. Pay over $100k for a motorhome like our previous, and you'll get the same issues. As for AC efficiency, we use the reflective bubble wrap stuff in most of the windows. All vents have cusions in them, skylight is painted and insulated with rolled and bubble wrap insulation. See my photo album for that one. All make a world of difference. And one more thing you can try that's mentioned again somewhere else on the forum, is insulate your return air boxes from the top side. Nothing between return air and outside heat but thin sheet metal. Remove AC cover on top of RV, spray adhesive, and put precut pieces on all sides of that box on the forward end of the ac. you could do the same to the inner side of the box If you unscrew and open it up. You'll be surprised how much these little things will drop the temp.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-29-2013, 10:10 PM   #7
Thanks for the tips on the hoses and the air conditioning. I've taken measurements for the window awnings; they're on our list of modifications. We're lucky that our problems are mostly fit and finish. I thought we had leaking slide out hydraulics, but it hasn't leaked since I cleaned up the mess. This is our third RV and, so far, has the least problems. We like the Level Up system; it simplifies set up. I'm undecided about the power awning. It's very easy to use, but it doesn't have the flexibility of the manual awning.
2010 Dodge 3500 SRW
Old 05-29-2013, 10:28 PM   #8
We became fans of the rear bedroom this trip - it's huge! There's room for some additional furniture back there. We don't like the dining room table, but the problem is having two entry doors. When sitting at the table, which is screwed to the floor, we block the main door. We're still thinking about how to modify the dining arrangements. We also have that loud annoying whine from the refrigerator.
2010 Dodge 3500 SRW
Old 05-29-2013, 10:59 PM   #9
New Silverback in use.
2010 Dodge 3500 SRW
Old 05-30-2013, 02:58 AM   #10
kc8lvy's Avatar
Nice looking outfit you have. There have been a few topics on here about the fridge noise and how to quiet it down.
Have fun
