We have a 2016 33IK ad have been fighting a holding tank odor pretty much since we bought it. Same issue when any fan is on be it bathroom, fantastic or even the vent fan over the stove the holding tank smell comes in through the heater registers in the floor or out of the heater return vent.
I first replaced my vents to the siphon 360 which did not help at all even though I think that was a good mod. I’ve owned 2 other RV’s and several large boats with holding takes so I know how to use chemicals. My dealer said is was improper use of chemicals but I know better. I flush my take after each trip to clear water runs and add chemicals for storage.
I just know there is a leak somewhere either in the tank or in the plumbing to the roof vents. I could not get my dealer to drop the underbelly as they said FR would not pay them enough in warranty time to do it and suggested I call FR.
Before I did that I performed a test to prove there is an air leak in the system bu connecting my leaf blower to the sewer clean out connection. I then lit a smoke bomb and fed the smoke into the leaf blower intake and cracked open the bayonet valve (yes, it was an empty cleaned tank..lol) and let the blower force smoke into the black tank only. I checked the basement and could see no smoke but as soon as I went in the RV I could smell the smoke and then saw it coming out the return vent on the furnace.
I sent the video to my dealer and they sent it to FR. I then got hold of Sullena Halsey at FR and she hooked me up the Orvin Fry of Amish Family RV Service who is going to take care of the issue. Unfortunately he is a very busy shop and said he could get to us in January. We are Floridians and no nothing about winterizing much less driving in such weather so we go in late April.
Long story, but hopefully your issue is easier than ours.
I would definitely start by checking the vents thru the roof. There was a very good post on here about someone who found that when the vent pipe was run to the roof they did not seal around the pipe and the exhaust from the vent could be pulled back into the RV when a fan runs. When the fan runs and your RV is all closed up it creates a negative pressure inside and try’s to draw air from anywhere it can.
Here is the post, I found it. Start at post #15..
http://www.forestriverforums.com/for...l-73081-2.html
I bet your smell is coming from the furnace return because you smell it by the front door as it heads to the bathroom.
Good luck.. it is definitely frustrating...
