Old 04-18-2012, 04:29 PM   #1
One Vs Two Air conditioners
Looking at the 38FL. Is the one 15,500 BTU air conditioner sufficient to keep it comfortable in TX, LA and FL summers? Would the second 13,500 BTU be necessary?
Thanks,
Tom
irish01 is offline   Reply With Quote
Old 04-18-2012, 04:37 PM   #2
Oakman's Avatar
Short answer is yes the 13,500 A/C would be necessary, unless you like to sweat.
Personally I think a trailer that is just over 40 feet long and has 5 slideouts should come with the two air conditioners as standard equipment.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-18-2012, 07:14 PM   #3
one vs two air conditioners
Having had campers with both set ups do your self a favor and go with the second unit you will be thankful you did.
Pitcrew18 is offline   Reply With Quote
Old 04-18-2012, 07:16 PM   #4
Get the second unit. If not needed, don't turn it on. If needed, you will wish you had it.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-18-2012, 07:37 PM   #5
textman's Avatar
Thanks,
Tom
Yes get the second A/C. well worth it those hot sunny days.
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 04-18-2012, 08:02 PM   #6
PapaSmurf's Avatar
I had two requirements, two AC's and more counter space... everything else was just bonus goodies. If I do not need two AC's I will only run one, but it is there when needed.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline   Reply With Quote
Old 04-20-2012, 08:30 PM   #7
We had three requirements: Two A/Cs, more counter space, and Steadyfast stabilizers.
2008 Cedar Creek 32TK
2001 F250 Lariat, SC, 7.3L, JW Towmaster tranny, 6.0 trans cooler, DP Tunner, Auto Meter Gauges, 4" turbo back exhaust, Firestone air bags.
overthehillbill is offline   Reply With Quote
Old 05-16-2012, 04:52 PM   #8
Slick salesman pointed out the new ducting system as alternative to needing a second air unit. That was more hot air than fact. Get the second unit.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
Old 05-17-2012, 05:18 PM   #9
kirk37r's Avatar
the answer YES we just took delivery of Our 2013 38FL last week. I just got home from dropping it off to have the front AC installed at the Dealer.
1 big tip! Check to see how that residential fridge is mounted in the cabinet!!!! PM Me for an explaination if you want.
I will tell you we had it out last week, Man its A beast. Towed great behind our GMC 3500 Dually. Loads of room, Just A great all around unit.
Good luck and keep us informed
kirk37r is offline   Reply With Quote
Old 05-17-2012, 06:36 PM   #10
Kirk37r Yes I would like to know what you know about the REFR. Unable to figure out how to send a PM. Me and this form have yet to reach an understanding after a year.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
Old 05-18-2012, 07:25 PM   #11
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
If you RV in TX LA or FL with an Rv of any size at all you will need the second air. If you have little kids that is more reason to have two A/Cs, more people = more A/C required. We had only one on last RV (30' Rear kitchen, 2 slides, no kids) new one has two A/Cs + thermal windows & 39'! It is worth every penny of the option cost.
Travel safe, enjoy your journey
Mike & Sheila
2013 36 CKTS Cedar Creek
'10 F350 Lariat CC DRW
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 05-22-2012, 09:16 PM   #12
We have 2 units in our 34' SilverBack and live in Houston.
Note that the 2nd unit, which you absolutely want, will limit you to 50 amp sites in the summer.
Keith & Liz
2010 SilverBack 33L
2009 F-250
kablair is offline   Reply With Quote
Old 05-23-2012, 12:59 PM   #13
B47
Kablair - good point on the 50 amp point - however, if you can't get a 50 amp hookup at a site, I guess you can always limp along on one AC and perhaps a lot of cold beverages.
Speaking about one versus two AC's, our 29rk came with one and has the wiring for a second installed.
I am currently talking with my dealer about having a Dometic Penquin 2 installed in the bedroom. One point brought up by the FR rep was that due to the lower ceiling height in the bedroom, a remote thermostat was not required as you can easily reach the controls standing on the floor.
Old 05-26-2012, 08:16 AM   #14
As far aa needing a 50 amp pole, an adapter can be bought that plugs into the 30 amp plug and a 15 amp plug to get you to 50 amps. They sell from$75 - $100. I use one with my generator when tailgating.
rmason8092 is offline   Reply With Quote
Old 05-26-2012, 05:58 PM   #15
kirk37r's Avatar
You just want to be careful when using one of those cheater plugs. Most of them will not work if you try to plug into A 15 or 20 amp circuit that is A Gfci. If you do you will still only have 30 amps and 2 ACs will not be happy at all.
FYI we just had the second AC installed in our 38FL. Man what A difference! That single unit really fought to push cool air up into the living room. Needless to say I mentioned to the owner of the dealership that anything over 36' should jt be ordered with the second AC.
Shoot if A 500.00 AC addon is A deal breaker then that deal should never be thought about anyhow
Kirk, Carol& Nicholas (Grandson)
2013 Cedar Creek 38FL, RV Cams rearview cam
2012 Ram 3500 DRW
CAUTION behind this truck is A contagious disease!!!
Its called Camping!!!
Old 07-25-2012, 09:56 PM   #16
Old Member
mikey's Avatar
Short answer. . .YES, get two! We had a 5er with only one 15000 BTU and it was a constant struggle in the TX heat. And that trailer had Arctic insulation and was only 29 feet long. Our new CC Custom 36CKTS (39+ feet) got two ACs and with the temps this year, we've been comfy whenever we got to use the trailer. Almost 6000 miles so far in 2-1/2 months so I'd say we made the right choice. With the old trailer we had to choose the time of year to travel so that the AC issue was not an issue for us.
Old 07-25-2012, 10:28 PM   #17
jimh's Avatar
two. mine came in handy while in SD...temp was 114. nights were cool.
last year we were next to a lake near Tyler, Tx and no shade. we were cool and the ones that stayed in the condo's weren't.
My reason was to have a spare if something happened to one of them in addition to the extra capacity. i also went with the heat pump...wasn't much more.
jimh is offline   Reply With Quote
Old 07-27-2012, 05:31 PM   #18
Full Timer
life2short4nofun's Avatar
I have a 2013 36B4 and got all the options including the two airs, double pane windows and am glad I did. I tried to run on just one air at the Good Sam Rally in Louisville last month because of only having 30amp hookups, and it got up into the 80s inside, so I ran my generator during the middle of the day so I could use both airs. Both airs run quiet a bit and they do seem to struggle some to keep it cool around 70, during the middle part of the day. So we planning on having a third put in the middle were the fantastic fan is. There are a couple fifth wheel brands like Elite Suites that come with 3 15,000 btu airs, and a lot of motorhomes. I think the idea of a fifth wheel with one air seems like really bad idea.
Ford Western Hauler
2013 CC 36B4
life2short4nofun is offline   Reply With Quote
air conditioner
