Old 11-08-2014, 01:20 PM   #21
kerjo530's Avatar
It connects to the roll pins right?
kerjo530 is offline   Reply With Quote
Old 11-08-2014, 01:21 PM   #22
kerjo530's Avatar
Yeah, we're trying, we just can't seem to get the crank bar to fit? This is a mess!
Old 11-08-2014, 01:28 PM   #23
Thats how i understand it, yes.
donniedu is offline   Reply With Quote
Old 11-08-2014, 01:47 PM   #24
Oops, sorry, i just went out and pulled my manual. It says nothing about manually cranking the rooms in. There is a troubleshooting section, but that is basic, ben no obstructions stuff.
It does give a phone number and web site. 866 524 7821 and ask for slide room technical support. Or www.cmsystemsinc.net
Old 11-08-2014, 02:09 PM   #25
I think if it were me, I would crawl under, remove the outer nut from the ram, and try closing. If the ram moves in, then you have a mechanical jamb. Put things back together, clear the jamb and close the room. If the ram does not move, them one of your selector valves is closed, your low on fluid, or your pump is not pumping.
Old 11-08-2014, 03:04 PM   #26
kerjo530's Avatar
Yeah, we gave up! Lol! Guess we are gonna have to pay a mechanic to come out and look at the hydraulic pump. It's running but it's sucking up all the fluid, it's not leaking anywhere we can see but it's got to be going somewhere. Time to call the professionals in! Was hoping to spare ourselves the cost!
Old 11-08-2014, 05:09 PM   #27
cedar creekin's Avatar
This is how I slid my sliders in manually.
Name:	camper slide.png
2003 cedar Creek 36 RLTS
Pushing an F350 diesel
Trailair
US Navy Persian Gulf Vet 1991-1994
cedar creekin is offline   Reply With Quote
Old 11-08-2014, 05:39 PM   #28
kerjo530's Avatar
Thanks for the pic, now we know we were doing something right! Www did try that, it wouldn't move so there must be a jam somewhere. That sucks! So we were doing it right.....now it's gonna cost us some money!
Old 11-09-2014, 10:05 AM   #29
It's not easy to turn. your pushing against the hydraulic ram. What I did was run the pump "in" for a few seconds, then crank by hand until resistance is felt. Run the pump a few seconds again then crank by hand again.
If yours wont budge at all than you have a jam somewhere.
Trailair
Old 11-09-2014, 10:58 AM   #30
Ok I'm going to try to help. Look at the end of the pump. In the middle, on mine, is a hex key entry way. You might have some tape or paper over the hole. Break through the covering and get the right sized hex key. I had to cut a hex key so I could use it with a cordless drill. Make sure that the hydraulic taps are in the open position. I have one for each slide on my 5er. That is, turn them all the way to the left if they aren't that way already. Insert the hex key and use the drill to bring the slides in. Now I have never done it myself so you'll have to experiment to find out which way to run the drill to bring them in, unless someone chimes in to tell you. Hopefully what I told you is what you have on your trailer. Good luck.
Pipeman is offline   Reply With Quote
slide
